Pll02A crystal info needed.
I saw that, but I'm not sure if they can pull 12+Khz. If you think so, I will try.
The xtals I got I was able to trim a full channel with a 40pf yellow trim cam.
Here is the specs I had the xtals made not many companies here in states that will cut xtals I think There is 1 in New Jersey they want $60 minimum for 1 crystalScreenshot_1.jpg
Reactions: Cable Guy
company i bought from in China has a minimum of 600 per frequency.
They will do samples but try Kens and if not try Bomar crystals the lady that runs the place hit me one tome for about $5000.00 for xtals about 5 years ago for about a few hundred xtals so I canceled when I saw the quote and found the place in China
