Imax2000 antenna.
9633
New Member
Dec 16, 2025
28
22
3
69
I have been comparing the Imax 2000 vs the Maco 5/8 wave antenna. Both have 5000 watt pep capabilities, just wondering what kind of success any of you have had with one or the other? I like that the new 2000 is longer and has more Bandwidth. Anyone have/use an Imax?
I have used all of the variants. Repaired all of the variants. Tested all of the variants. The current Imax is trash. The old Imax is old. The Maco is not going to fall apart within 18 months, as an Imax will and won't have RF on the coax shield.
There is better than a Maco out there, but if I had to choose between them, I would pass on the Imax.
What should I look at that is better than the Maco? The other ones appear to be junk. Thanks
I really like the Imax because I can use it for 17M-10M with my tuner, 17M is only good when the conditions are Ok. I know its not as robust as my Maco 5/8's. I will say you want to limit the Imax to 1KW max!!!!!! The only time I have damaged the Imax is when running more the 1KW. It IS NOT SAFE TO 5KW as far as I have experienced. If your only going to use one band, either 11 or 10 meter I would suggest the Maco. If you are a Ham and want multi bands with a vertical I would say go with the Imax and a tuner. The ground plane kit is also needed for the Imax so don't skip that add on. When testing both side by side no one ever says one is so much better then the other and my receive is basically no difference either between the two. Both are mounted at 23' to the bottom of the support of the antenna base. Side by side is a bad statement, they are about 40' apart. As stated there are better options out there but these are the only two I have owned that are up in the air. I do have the Siro Vector 4000 but have not even opened the box yet.
Reactions: 9633
The Ground plane kit is my Problem. My House is surrounded by Trees, so without hiring a Tree Trimmer to remove a lot of limbs and Branches, I'm leaning towards the Imax. I have had good luck with the A99 so far.
