MY11M megalodon, Yagi antenna build
Geoexplorer69
68
53
28
57
So after looking at the selection of eight element Yagi antennas oh wait I didn't find any. I decided that I could build a better one for less money that would ot perform anything Any company out there could produce. I have a bunch of 6061 2 1/2",and 3" Square tube I can easily source heavy duty aluminum elements at least the aluminum tubing to make the elements thy will be heavy walled and telescope largest diameter to the smallest diameter at the tip. DX engineering has all the little parts and pieces and mounting hardware I could ever want, including truss line and stainless steel hardware so I sharpened my pencil get some calculations and here's what I came up with and by the way, I am gonna build this. That's just the kind of guy I am.
The boom's finished length will be 48 feet. I'm building this as an OWA Yagi antenna it will be direct fed from a.max 20 1-1 balun and tuned either at 27.525 MHz or 27.550 MHz haven't got down to that part yet however this sets perfectly in line with the frequencies that I run also knowing that this is going to have more of a U-shaped curve as far as SWR rather than a steep drop off or V-shaped if God forbid you're dumb enough to use a gamma match and to those of you that are using gamma matches yes I have one on my four element.serio and that's the reason why I don't like gamma matches. Even if you convert to a hairpin match, you're still run into the same problems on band width not so much for tuning. A hairpin is superior to a gamma match imho. And if you wanna argue about it, well please go argue with the closest wall in your residence. Thank you..
After looking at this and deciding OK, let's get some metric tape measures out and start figuring this stuff up. Let's get a hold of DX engineering and get the parts coming. I started doing some numbers on the DBD and the DB ground reflection gain ( DBI is all marketing hype )then I looked at the ERP. Wow, just wow and I don't push power well any more power than my 991 can pump out but I do use high-grade coax Messi and paoloni ultraflex 10 including their proprietary connectors so there's gonna be something like a .6db or so line loss in the 97 feet run that I have including the rotor loop. So yes I do have an amplifier but it's only a 200 W custom built fully A/B biased side band only with Toshiba C pills. no preamp.
I'm working on the direct element spacing right now because my 64 year old brain suffers from some CRS I take a lot of notes. I ask Google AI stuff but the problem with Google AI is that it has cost me money and hair loss by giving me bad information and lots of times I have to go. Hey, are you sure maybe you should sharpen your AI pencil or double check your data .
so what am I getting at? thank you for asking !
All right the bottom line is, I'm not bragging what I need is a great antenna builder to chime in preferably somebody in Europe or Australia or any place besides the USA that uses metric measurements and let's see if our numbers for the spacing between the Director and the first reflector spacing the rest of the elements and other measurements can jive , and yes, I am running dual truss lines to keep it perfectly flat I know the angle that I need to run from the top of the mast extension so that is dialed in.
It would be absolutely awesome to hear from some great antenna builders your honest input, other than that YES I am absolutely nucking futs that has already been established.
Cheers
Reactions: Crawdad
If you have or can download EZNEC Pro 2+ v7 (free download), you can design and tweak your Megaladon yourself in metric dimensions without much trouble.
Good luck with your monster.
7 3
Reactions: Geoexplorer69
7 3
Hey, thanks for the reply. Yeah I looked into that definitely gonna use it and since I'm posting on here again, my bad for thinking there wasn't anybody building An 8 element Yagi. There are a few, but their booms are either too short or too flimsy for my liking
Your boom will definitely need some beefy square tube, beefy splices and guys. You should be a EU powerhouse with 8el on 11m.
Yes true but I have enough 6061 t6 2 1/2" heavy wall square tube and I have 3" as well also my plan is to use a 3" square tube section 12'-13' long for the center and run 2 1/2 " for the outer booms they fit nice n snug together then I have the DX engineering clamps and mounting gear to run the elements underneath the boom the mast will stick up 5' above the mounting plate, and then I will run two each guidelines from the truss top on either side, I have the stainless steel hardware and the turnbuckles to support the boom and enough for two sections either side of the truss pipe. I already have a spool of mastraint-M 3mm line for the guy lines on the boom.
Right now, I'm just doing the number crunching on the element spacing and lengths I have a bunch of different size diameter heavy wall aluminum tube that should work well for the elements probably gonna be overkill, but that's OK then I decided to split the ends and use some of the stainless steel split end clamps from DX and also to run some sections of small diameter, Poly line Down through the center of the elements to keep any harmonic wind vibration that I'm sure I'm gonna get way out here in the SW desert dampened down.
That's my plan anyway thank you
Reactions: Crawdad
Keep us posted on your build, if you care to, and photos would be great.
7 3
Reactions: gamegetter
Yeah, I will and when I get this beast built I’ll snap some photos right now. I just have the aluminum square tube the big heavy duty element aluminum tubing that I’m gonna use starting out 1 inch and tapering down just ordered the. Max20 1-1 balun from DX engineering and a whole box full of other assembly parts. This is going to be a project that’s gonna stretch through November and probably December before I get it. Tuned and get it up and get one of the parts I have to wait for to because I’m putting together a.MaCo 106 with the 31’ boom right now and I have to wait on a hairpin kit for that 106 coming in from DXE and another max 20 1-1 balun and some hardware and truss line ect . Yeah I had to order a new adapter.Ntype to so239 for my MFJ 226 analyzer so that’s actually the one part that I’m waiting for ahead and bit the bullet this time and got the Amphenol RF the one I should’ve got that thing in the first place instead of thinking I could save some money on anything that uses an N connector . Anyway, I’ll keep anybody interested apprised of the situation. And like I said, I’ll get some pictures out as soon as the whole thing built and tuned up and sitting on top of my monster tower. Cheers
Reactions: Crawdad
The megalodon update
OK so I've got it all put together. We put it up the other day on a 42 foot test pole just so I can get some readings on my MFJ 226 antana analyzer. And she's running really good nine elements on perfectly spaced. DX engineering max 20 1-1 balun mounted tuned perfectly so I thought before some pictures cause I don't want to take any pictures until she's up at 48 feet !!!!
Right now I'm waiting on a big rotor and controller for this beast. I'm looking at picking up a green heron 21 Yaesu 2800 rotor package from Green Heron . We didn't try to shoot any skip. I just needed to get some numbers while I had enough able bodies to help me get this thing up and down on the 42 foot test pole so here's the numbers we got.
At the bottom of my sweep and the bottom of my band spread that I have the Yagi set up for which is 27.360 R=44.5 X=-j4.8 ohms capacitive. Target SWR 1.11to1.... , Smith chart plot loop slightly into the bottom, left quadrant. 27.680Mhz center freq R=50.0 Ohms reactants =X=0 .00 Target SWR = 1.0. Smith's chart plot sits dead center in the prime 50ohm circle .28.000MHZ top of band spread R=55.8Ohms X= +j5.5 target, SWR 1.1 4.1 chart, visual plot, drop slightly into the top right quadrant.
OK maybe we'll get some pictures up here in the not too distant future, and I don't know if I mentioned it, but I decided to go with 6061 T6 1 inch tube and taper down to 6061 T6 7/8 inch for the outer tips.
I'm happy with it for now .
On my mako 106C 31' boom flat 6 build that's just done. I decided to make it an OWA so I converted it completely to an OWA design as well. The hell with hair pin or gamma matches.
There's an understatement. The one with two worm-drive gears would probably be apropriate. Can't remember the name of that one just now.
I believe you’re thinking of the tail twister or something similar I have every bit of confidence in the yaesu 2800 rotor green heron 21 rotor package
The italian Prosistel rotator used a single worm gear with the motor's axis sticking out the side of the tower. This guy went one better, driving the main worm gear with a second one parallel to the tower. Looked bullet proof to me. Just can't remember the product name.
I had two of the Prosistel 2051's. Had to replace the potentiometers in both of them within a year. I found out after I bought them that this is a common problem with all the rotators from this company.
You can't replace the pot with the rotator in the tower. You have to fix it on the ground.
Replaced both Prosistels with the Yaesu G-2800DXA.
Cheers
The larger diameter of the driven element the broader the band coverage.
