MB8719 with 11.1125 xtal mod
Techno1
244
70
49
New Hampshire
Has anyone tried these 2 channel mods using the mb8719 and the 11.1125 xtal to get high and low channels.
I know about changing the xtal to the 11.3258 and get the channels.
See the 2 pictures I tried the rotary sw one and would not work with the 11.1125 xtal.
I tried it on a 148gtl NW radio.
They say this mod will work on a Washington/142gtl and radios with the 8719/11.1125 combo.
There is a channel list of the channels u r suppose to get. I again could not get the rotary sw to work.
The pin 17 mod above is twitchy. The setting of L18 is sensitive to temperature. Not such a big deal for a base radio, but too sensitive to be reliable in a mobile. Quirky and interesting, but potentially unreliable.
I remember a mod where pin 10 is brought to some mid rail voltage that allows P6 to be read as high before the internal inverter turns P7 (internal) low (which makes P6 and P7 both high). If this mod uses the Fin bias to achieve that, I would put that directly into the sketchy category.
