Luiton LT-8001 Pro AM, FM, SSB
Thanks. I was wondering if it did actually have SSB.
It's a pretty sharp looking radio.......is there a picture of it with the display lit up?
Simon says that the 8001 is being replaced by the 8003. They seem to be the same radio with a different look.
Reactions: Woody-202
I'm super wary of those blue displays. The infamous Bearcat 980 had blue and they faded away to nothing after a couple years. The CD decks in the radio station where I work had blue displays, and they didn't even last three years before fading away & becoming invisible. My blue LED clock's digits faded away after about five years, as did the blue display in my friends Yaesu ham radio (forget which model). That one lasted longest at about ten years.
Not sure I'll be buying any more devices with blue displays until they figure out how to make them not fade out after just a few years!
I am getting a little seat time with the 8001, and it seems that I have a different version than the one Wagon Master has. Namely, the AI noise reduction does not appear in the menu. Menu item 1 for me is to select a roger beep, not the AI noise reduction feature, and AI does not appear anywhere in the menu. I will have to inquire about the software version. I am confident the AI noise reduction feature will overcome the shortcomings of not having a noise blanker.
The display color can be changed with a button on the front. I believe red would be good for night time driving.IMG_20261115_145658105_HDR.jpg
I'm not convinced theirs enough resolution on that frequency counter! :) Be interesting if those extra zeros actually change.
All but the last zero can be changed by the clarifier. If you turn the clarifier, that becomes the new frequency for that channel.IMG_20261115_150151543_HDR.jpg
So it overwrites the memory unless you change it back?
The first generation quad 6 and clones does that as well.
Firmware fix maybe?
Have to say that I like the red display above.
So much better than blazing blue.....
