Questions about VFO options
Illahe
New Member
Jun 3, 2026
33
14
8
57
Hello all,
Anyone messing arround with VFO's? My question is about pairing a VFO with a Galaxy 959 or a Uniden 980 for 20 meter use. Is this possible?
Thanks,
That's not possible. The circuits of the 959 and the 980 and all other CB and export radios are designed to operate in the 25 to 30 MHz range......primarily on 27 MHz. It is possible, at least with export gear, to operate on the 10 & 12 and sometimes even 15 meter bands. You would need to purchase a radio such as an Anytone 5555N2 or similar. But because the the 20 meter band is on 14 MHz it is way to far outside the design specs of the circuit in a CB type radio. Same with 40 & 80. Keep in mind too, that an antenna designed for 11 meters will only work outside that band if you use an antenna tuner.
If you want to transmit on 20 meters you need a ham transceiver and the correct antenna for the job.
Reactions: midnight special
I understand the L networks are configured band specific, but I'm not clear on the application of VFO's.
I have a TS 130, but I would like a simple 20 meter mobile. Any suggestions are welcome.
Your reply is appreciated.
I understand the import SMT transceivers are out of discussion, as the l network is band specific. My specific question was/is about grasping an understating of all the club-"kit" VFO's floating around the web and the china vendors. Some don't seem to be stand alone transceivers, rather VFO board, so I am trying to conceptualize what they are using for the transceiver, itself.
Reactions: BC Coyote
Kenwood TS-50, Yaesu FT-857 +its varients, & the Icom IC-706 are all great mobile HF rigs that have been around for awhile and have good solid reputations.
Thank you.
I will look into them. For mobile I'd be happy with 20 m and a variable inductance antenna like the ATAS 120A though it's limited on wattage caring capacity.
At coffee this morning, I asked some of the members what they did back in the day for mobile transceivers and it seemed pretty slim pickings. So it led me to believe the VFO kits where driven by their needs for a mobile option.
Thank you.
I don't know what VFO kits you are referring to, but a CB is too far out of the RF design range, to go on 20 meters. Could it be done? Perhaps.... But, you said simple, which this exercise, is not.
I ran a TS-130S mobile a long time ago. I have also had several other HF radios in vehicles. Cubic Astro 150A, Icom IC-735, Yaesu FT-100, Icom IC-706MKIIG, Icom IC-7000, Motorola Micom. This was 20 years or more in the past. I have not been running HF mobile in some time now. I used many HF antennas. Some were the hamstick type, some outbacker type, some hustler type and some screwdrivers. The best was the Hi-Q, with an auto tune controller.
Thank you for the response it is appreciated.
What made me question the marketing of VFO kits, like the is the product detector (if that's the correct term) in the ssb transceivers. Obviously after the final it goes through the L network and out the SO239. So the final would need to be able to operate efferently at 14.000~ and the L network would need to be clean within the desired band. There are countless band pass filters available along with cheep mosfets.
My understating is that the transceivers have a base frequency, which is applied the the vfo and mixes to the desired frequency. What information I can gather is that the vfo is voltage sensitive and that's how the frequency is tuned.
I will look into the Hi-Q.
Purchasing a transceiver is not the issue, I'd like to know the operational science behind them, and how/why the kits are so popular.
The VFO you referenced, is not something that would be used with a PLL. It is to "synthesize" a crystal controlled oscillator.
There are DDS VFO's, that have been implemented in PLL radios and crystal matrix radios, that operate within their design range.
Hi-Q, is a thing of the past. If you decide to get one, it will be from an individual party, used or not, by that party. I also have High Sierra screwdrivers. They were okay, but the Hi-Q was much better. High Sierra, is also history.
Thanks again, the knowledge is appreciated.
Is this an offshoot of the design you are referencing?
