Cobra 25 stinger set up
Illahe
New Member
Jun 3, 2026
14
8
57
Question: Installing a 1446 stinger pallet in a Cobra 25 chassis that requires 2 w DK. I'm aware of the cap and resistor mod to lower DK. Is there another option that doesn't need heavy mic gain to open up the 4:1. Most of the time they run in the 10W region modulating sans stinger.
Back in the day we advised the drivers that you need variable only if you'll use more than one amplifier. Different amplifiers have different drive requirements. For an over-the-road combo of just one radio and just one amplifier, the resistor mod is simpler, one less knob to turn the wrong way.
Your stinger will probably require around a half Watt to keep it below 10 or 15 coming out. A former employee had a method. He kept the 1-Watt resistor values from 68 to 150 ohms handy, and would use two gator leads. The jumper wire would get cut, and one gator lead to each side of the cut. Trying one then another value resistor would zero in on the desired carrier from the linear. That value got soldered in, and the capacitor added. This is not useful advice unless you have the range of resistor values on hand to try. He got tired of this method and used a 5-Watt wirewound 250-ohm pot on the gator leads. Once the desired carrier level was set, it got unclipped and measured with the ohmmeter. The closest fixed value to that measurement would go into the radio.
Naturally he tried a pot with a smaller Watt rating at first, and it kept wearing out. I explained that if the circuit was using only one quarter of the resistance element inside the control, the Watt rating was a quarter of a Watt, not the full one-Watt rating of the control. We had a 250 ohm 5-Watt pot in our inventory, and it didn't wear out prematurely.
We found it necessary to put a .01uf disc cap to ground from the end of the cut jumper, the rear end that leads to L13, the driver collector coil. Some versions have that capacitor, some don't. If it's there, you don't need to add one.
Have fun and 73
Reactions: Illahe
Have fun and 73
I like the schematic that " Uncle Ronnie" posted as well. I get the test procedure you have outlined! saves some trial and error. I have found that the DK on "swing kit" 29's I have done will increase after I tune l14, at times going from 1w to 2.5~. Your method is duly noted.
The thread Ronnie linked also has a board with a high and low adjustment, which I find feasible. Especially if someone get happy with the mic gain.
