Luiton LT-8001 Pro AM, FM, SSB
At least it has a couple of potentiometers. Does it swing hard or clamp down? And what does it pep.
The power is reasonable and it will do 100% modulation on AM. I have not made any adjustments inside because I want to wait until I try the programming software. The carrier power is adjustable from 1.5 to 8 watts, and it will do about 35 watts peak with an 8 watt carrier. If you turn the carrier down, the peak goes down to maintain 100% modulation. Some kind of NPC mod would help if an amp is used AM mode. The FM power is about 45 watts and the SSB peak is also about 45 watts.
The tx audio has a good balance of highs and lows and I believe the software has some sort of equalizer adjustment too. The electret mic has clear and clean audio and should do great in a noisy environment with the AI noise reduction.
Thanks. I was disappointed with the QT 40 and wondered if Radioddity got the modulation strained out.
Every qt40 I've heard on the air I've given flowers to and everyone I know that has one loves it. I guess it's the first complaint I've personally heard about the qt40.
I guess if you're looking for a needle slapping Am screamer then the qt40 would leave the Am'r displeased. On the crisp clear ssb side of things it's a completely different story because they have superb audio.
I had no complaints over the air and made a momentary contact with an Au station on 38LSB. I wasn't pleased with the clamped down modulation and the over rated AM PEP. After the internal menu options locked up it went back to where it came from. To each their own, they say...
