New to CB again
petehdgs
New Member
Nov 27, 2026
5
4
3
67
Hello to everyone!
I used CBs from the 70s in high school through the 90s when I started using cell phones. I recently saw a YouTube video about CB coming back and why, by Hank Ludlow. I have since watched dozens of videos to educate myself from content creators like FarPointFarms, CoasalWavesandWires, and several others. I am learning a lot and am interested in sharing and reading about others. I already belong to two other forums, Pilots of America and the Trawler Forum. So here is part if my story....
I grew up on a farm in Virgina and have been around all types of machinery since I could walk. After High School I went o Nashville Auto Diesel College and then to the CAT Dealer in Richmond. In January of 1979 I started working in the industrial engine/generator business, and have been in that business ever since. I worked for Alban Engine for 20+ years and started GenTune (repair and maintenence) in 2006. So about a year ago my wife says "What are you going to do when you retire? All you ever do is work!" I took flying lessons in 1979 and again in 2004 and got my private pilots license and a plane. My dad and his friends and I got involved I the Jamer River Batteau Festival from about 1991-2006, and I really liked being on the river for 8 days every year. So my wife's question really shook me up a little.
I run my own generator maintenence business and have a couple of good guys working for me, I like to fly and I like the water, but I really need to look at all of it. I am 68 years old, and sooner or later I'll have to back off some. I'll probably sell my plane before I turn 75. I'd like to cruise on the Great Loop but I don't want to be away from home for a full year doing it. SO I bought a trailerable cabin cruiser built in Nashville in 1978. I am restoring/rebuilding it with some help. I plan to spend 1 week every month on my boat somewhere along the great loop, and spend most of the month running my business and maintaining my boat.
How did I come back to CB? While I don't own one, I know that SSB CB is good or about 35 miles mobile to mobile, and it will work in remote areas where cell phone coverage doesn't go. So that led me to investigating SSB CB. I figured it would be a good way coordinate my boat and ground vehicle interaction. I have since learned about the rules changes for LONG DX and FM, and what each part of the band is good for. So I am now pursuing things I haven't ever done. I am working on hanging a verticle dipolec from a tree for my base station, and putting CBs in my car and service truck. I bought a President George because it has everything and I am looking for a couple more that are less expensive. I found a deal at ALDI on line for a President SSB AM only for $30 each. ( I hope that is not a scam ) I am going to have alot of questions about what I can and can't do, especially with antennas and base station wiring, so I was looking for a forum to bounce ideas off of.
My name is Pete Hodges, petehdgs@yahoo.com and I think my handle should be GenMan-79, but to be fair I don't remember my old handle and I am open to suggestions. For my other forums I use petehdgs and I'll use that here too, but it isn't a good name to use on the radio. What do you guys think? I am open to suggestions.
Thank you for reading.
Hello to everyone!
I'm sure you are aware of this, but CB radio
on the 11 meter band is a short communication hobby. It's nice to understand the rules, but I wouldn't be too concerned about them. What I mean about that statement is that a lot of people have always abused the rule book from the FCC on the CB band. A good example are the boys on channel six when the skip is rolling.
You mentioned putting up a vertical dipole in the trees. Well that's fine if that's all you can afford, but don't expect to communicate many miles, unless you live on top of a mountain. I got into CB radio just before the CB craze came on the seen in the late 70's, and over the years I learned that the antenna system is the most important part of a radio station. It's even more important than a expensive radio and amplifier. For a base antenna I use RG213 coax along with a good commercial base antenna.
It sounds like you might like to spend a lot of time on a boat. Well since boats are made from wood and fiberglass, you will have RF ground problems with the antenna system. They do make a no ground plane (NGP) antenna where the coax makes up the other electrical half of the antenna. NGP antennas don't transmit the RF signal as far as a regular 1/4 or 1/2 wave mobile antenna would, but it's better than nothing. Now days trucks and cars have a lot of plastic on the vehicles body, so RF ground is a big issue. If you run into this type of problem, then it's possible you may have to do what's known as bonding.Hopes this advice helps some.
Reactions: petehdgs
I make contacts on the dipole all the time. 2000 miles and more. The dipole is one of the many economical options to get on the band. They are about $60 or $70 bucks for a decent one. The Falcon is a decent one for the price point.
Being located in Va. you should have no problem making contacts, but you'll be compromised on AM as there are some "strong" stations in your area.
Spending the extra $ for a dual final unit is the minimum.
Reactions: petehdgs
Yes that is true, but I was basically talking about the 11 meter band in general when the skip isn't rolling. I should have clarified that. When the band conditions are just right, it doesn't seem to matter what antenna you use. But when the band is dead, your 3 or 4 watt cb radio needs all the help it can get. That's why I recommended a good commercial antenna over a wire antenna. If a wire dipole is all a person can afford, or maybe an HOA prevents them from putting up a decent antenna, then by all means use the dipole. I've successfully used wire dipoles for years, but not on the 11 meter band. The dipole antennas are kind of a high maintenance antenna, the cold icy winters are hard on them, so you have to check on them often.
Reactions: petehdgs and Illahe
I can see that. I use a Tram on the mobile and it gets out; with a little "help" its even better.
Hopefully he stars with a dual final or an import radio so he isn't quashed when he keys.
Reactions: petehdgs
I used a wire sloper for all my local work on 11. #10 AWG aluminium was maintenance free for 8 years. Admittedly, Vancouver isn't hard on outdoor anything (as long as it's waterproof).... wind rating is more important for winter gales than temperature or ice.
End fed? From what the OP said, I like low cost to get on the band. Then set up a station that fits his capacity, and needs.
Reactions: petehdgs
What does dual final mean? I think import radio means more power but I am asking because I don't know. I am new again and don't know much but I am learning.... Right now I am interested in starting with one or two base radios and a vertical dipole. Add a radio in my truck and car and experimenting around with those. That is a cheap way to get started and there is no sense spending a lot of money without at least some experience. I am trying to learn as much as possible, especially about antennas since I don't really understand them. That should keep me busy for a little while.
Reactions: Illahe
Dual final means the final RF amplification stage has two output transistors. It's supposed to double the output of the radio, but results may vary depending on component tolerances and technical skill of the last person to do an alignment.
Reactions: petehdgs
Question, when you say, "starting with one or two base radios" are you referring to a base station, like a cobra 142 GTL, or say, something in the order of a Galaxy DX2517.
Reactions: petehdgs
My only words of advice are stay away from anything built by RCI. That includes ALL Ranger radios, Galaxy radios, and anything else built by RCI.
They all drift like mad on sideband, have defects like cold solder joints and warped circuit boards, and their quality control is basically non-existent. They are also stuck in the 1990's when it comes to technology and innovation.
If you are going to buy a new export type radio, get a Radioddity, Anytone, or one of their clones such as CRT. Or better yet get a used ham rig from Icom, Yaesu or Kenwood and do the MARS mod on it.
Remember, friends don't let friends buy Ranger radios!
Reactions: petehdgs and VMC
Thanks for the words of wisdom, they are duly noted. I guess I'm still stuck in the through hole board era...
Neither of those. I bought a President George because it has everything, AM FM USB LSB and FM privacy codes. I was looking for a Mickinley 2 but nonprivacy codes and they are mostly out of stock now. I made a sale purchase of 2 President Deluxe AM USB LSB from Aldi on line for $30 each. I hope this not a scam, but a DIN size and fron speaker appeals to me, and the price is good. That ought to be enough to start playing. I'd like to be able to operate from two different locations at my house, that's why I said two radios. Gotta figure that out. One Miracle at a time!
So, I have three applications. Base, car/truck, and boat. None of my purchases are here yet and the boat is having the upper deck replaced, so I am learning about antennas and CB radio, mostly by watching YouTube videos on these subjects. I bought a Wilson little will for the car, and a Dipole kit for the tree. I have been asking Google AI a lot of questions based on what I have learned. Today I asked about Centerpoise Antennas and how to build a boat antenna using these principles. You guys have more experience than I do. I have this antenna designed with 2 u shaped ground radials, sloped down at 22.5° with a removable whip for towing and bridges, and stowed with the centerpoise parallel with the keel. The base will telescope 4-8 feet to clear the flybridge and angle to rotate 90-120° Everything is a compromise on a boat.
What do you think?
The end result is listed here below.
AI Mode Conversation​
You said: now that we have the antenna designed with u shaped counterpoise at 22.5° down, what is the proper name for it?
The proper name for this configuration is a drooping ground plane antenna (also commonly called a 1/4-wave ground plane antenna with drooping radials or an inverted-V ground plane).
While your specific physical build uses a continuous wire bent into an open-ended "U" shape at the base rather than two separate wires, electrically and functionally it operates as a two-radial drooping ground plane.
Here is how the specific features of your design break down in standard radio terminology:
    • 1/4-Wave Ground Plane: Refers to the vertical radiating element working against an elevated artificial ground (your counterpoise), rather than being mounted directly to the earth.
    • Drooping Radials: Angling the counterpoise wires downward (at your 22.5° angle) raises the antenna's feedpoint impedance from roughly 35 ohms closer to a standard 50-ohm match for your coax, without needing an external matching network.
    • Two-Radial / Bi-Directional Counterpoise: Because it uses two opposing legs (formed by the U-shape) instead of three or four, it creates a slight oval or figure-eight bias in the radiation pattern rather than a pure circle, though it remains broadly omnidirectional.
If you are logging it, describing it to other operators, or looking up modeling data, calling it a quarter-wave ground plane with 22.5° drooping radials will immediately tell any radio enthusiast exactly how it is built and how it performs.
Would you like help with:
  • Tuning procedures (adjusting wire lengths for the lowest SWR on 27 MHz)
  • Coax routing and choking (preventing common-mode RF on the feedline)
  • Expected radiation angles for local vs. skip (DX) contacts?
What are the Expected radiation angles for local vs. skip (DX) contacts?
For your 1/4-wave drooping ground plane antenna on 11 meters (27 MHz), local contacts rely on low radiation angles near the horizon (0° to 10°), while skip (DX) contacts rely on takeoff angles between roughly 5° and 25°, depending on how far away the receiving station is.
Because your counterpoise radials droop at 22.5°, your antenna naturally concentrates its maximum signal lobe right around 15° to 20° above the horizon (depending on mounting height), making it well-suited for both local ground-wave and medium-to-long-range skip.
1. Local Contacts (Ground-Wave / Line-of-Sight)
  • Target Angle: 0° to 10° (hugging the earth's surface).
  • How It Works: Local contacts (typically within 10 to 40 miles) do not bounce off the atmosphere. They travel via direct line-of-sight and ground-wave propagation.
  • Your Antenna's Performance: Vertical antennas naturally push strong energy right along the horizon. Getting your feedpoint 30+ feet high clears local terrain, trees, and roofs, maximizing this low-angle horizon energy for local talking.
2. Skip / DX Contacts (Skywave)
  • Target Angle: 5° to 25° (aimed up toward the ionosphere's F2 or E layers).
  • How It Works: To talk hundreds or thousands of miles, your signal must shoot upward at a shallow angle, refract off the ionized upper atmosphere, and bounce back down to earth.
    • 15° to 25° (Medium Skip): Typically lands 600 to 1,200 miles away on a single hop (e.g., reaching the Midwest, Florida, or New England from Virginia). Your 22.5° drooping ground plane peaks right in this sweet spot.
    • 5° to 12° (Long-Haul DX): Grazing angles just above the horizon stretch a single hop out to 1,500 to 2,500+ miles (cross-country or international).
    • Above 35° to 40° (Too High): At 27 MHz, signals aimed too steeply upward usually punch straight through the ionosphere into space rather than bouncing back down.
Quick Summary by Contact Type
Contact TypeDistanceIdeal Takeoff AngleHow Your Design Performs
Local0–40 miles0° – 10°Strong horizon punch (improves with height)
Regional / Medium Skip600–1,200 miles15° – 25°Peak lobe zone for 22.5° drooping radials
Long-Distance DX1,500–2,500+ miles5° – 12°Good low-angle lobe, especially mounted 1+ wavelength (~36 ft) high
(Note: Raising the feedpoint closer to 36 feet—one full wavelength above ground—helps pull your main radiation lobe down toward that lower 10°–15° range, boosting both local range and long-distance DX at the same time.)
Would you like to look at:
  • How mounting height (e.g., 20 ft vs. 36 ft) shifts the takeoff angle on 11 meters
  • How to build a simple coaxial choke to keep feedline radiation from distorting this pattern
  • Step-by-step SWR tuning once you get the antenna mounted?
Reactions: MKwrench
