New to CB again
Neither of those. I bought a President George because it has everything, AM FM USB LSB and FM privacy codes. I was looking for a Mickinley 2 but nonprivacy codes and they are mostly out of stock now. I made a sale purchase of 2 President Deluxe AM USB LSB from Aldi on line for $30 each. I hope this not a scam, but a DIN size and fron speaker appeals to me, and the price is good. That ought to be enough to start playing. I'd like to be able to operate from two different locations at my house, that's why I said two radios. Gotta figure that out. One Miracle at a time!
The Aldi thing sounds too good to be true, double check your CC to make sure the $$ and correct amount went where it's supposed to.
Good choice!
As long as you purchased with a CC. your protected.
I believe the McKinley is the same board as the Uniden 980. Not sure about the George but the chassis looks similar. Look up Custom CB Radio in Ohio, he knows them well; after a call to President, they sent me to him when I was looking into "expanding" the President Ronald.
The McKinley pairs well with a budget "foot warmer."
Reactions: petehdgs
So, I have three applications. Base, car/truck, and boat. None of my purchases are here yet and the boat is having the upper deck replaced, so I am learning about antennas and CB radio, mostly by watching YouTube videos on these subjects. I bought a Wilson little will for the car, and a Dipole kit for the tree. I have been asking Google AI a lot of questions based on what I have learned. Today I asked about Centerpoise Antennas and how to build a boat antenna using these principles. You guys have more experience than I do. I have this antenna designed with 2 u shaped ground radials, sloped down at 22.5° with a removable whip for towing and bridges, and stowed with the centerpoise parallel with the keel. The base will telescope 4-8 feet to clear the flybridge and angle to rotate 90-120° Everything is a compromise on a boat.
What do you think?
The end result is listed here below.
AI Mode Conversation​
You said: now that we have the antenna designed with u shaped counterpoise at 22.5° down, what is the proper name for it?
The proper name for this configuration is a drooping ground plane antenna (also commonly called a 1/4-wave ground plane antenna with drooping radials or an inverted-V ground plane).
While your specific physical build uses a continuous wire bent into an open-ended "U" shape at the base rather than two separate wires, electrically and functionally it operates as a two-radial drooping ground plane.
Here is how the specific features of your design break down in standard radio terminology:
    • 1/4-Wave Ground Plane: Refers to the vertical radiating element working against an elevated artificial ground (your counterpoise), rather than being mounted directly to the earth.
    • Drooping Radials: Angling the counterpoise wires downward (at your 22.5° angle) raises the antenna's feedpoint impedance from roughly 35 ohms closer to a standard 50-ohm match for your coax, without needing an external matching network.
    • Two-Radial / Bi-Directional Counterpoise: Because it uses two opposing legs (formed by the U-shape) instead of three or four, it creates a slight oval or figure-eight bias in the radiation pattern rather than a pure circle, though it remains broadly omnidirectional.
If you are logging it, describing it to other operators, or looking up modeling data, calling it a quarter-wave ground plane with 22.5° drooping radials will immediately tell any radio enthusiast exactly how it is built and how it performs.
Would you like help with:
  • Tuning procedures (adjusting wire lengths for the lowest SWR on 27 MHz)
  • Coax routing and choking (preventing common-mode RF on the feedline)
  • Expected radiation angles for local vs. skip (DX) contacts?
What are the Expected radiation angles for local vs. skip (DX) contacts?
For your 1/4-wave drooping ground plane antenna on 11 meters (27 MHz), local contacts rely on low radiation angles near the horizon (0° to 10°), while skip (DX) contacts rely on takeoff angles between roughly 5° and 25°, depending on how far away the receiving station is.
Because your counterpoise radials droop at 22.5°, your antenna naturally concentrates its maximum signal lobe right around 15° to 20° above the horizon (depending on mounting height), making it well-suited for both local ground-wave and medium-to-long-range skip.
1. Local Contacts (Ground-Wave / Line-of-Sight)
  • Target Angle: 0° to 10° (hugging the earth's surface).
  • How It Works: Local contacts (typically within 10 to 40 miles) do not bounce off the atmosphere. They travel via direct line-of-sight and ground-wave propagation.
  • Your Antenna's Performance: Vertical antennas naturally push strong energy right along the horizon. Getting your feedpoint 30+ feet high clears local terrain, trees, and roofs, maximizing this low-angle horizon energy for local talking.
2. Skip / DX Contacts (Skywave)
  • Target Angle: 5° to 25° (aimed up toward the ionosphere's F2 or E layers).
  • How It Works: To talk hundreds or thousands of miles, your signal must shoot upward at a shallow angle, refract off the ionized upper atmosphere, and bounce back down to earth.
    • 15° to 25° (Medium Skip): Typically lands 600 to 1,200 miles away on a single hop (e.g., reaching the Midwest, Florida, or New England from Virginia). Your 22.5° drooping ground plane peaks right in this sweet spot.
    • 5° to 12° (Long-Haul DX): Grazing angles just above the horizon stretch a single hop out to 1,500 to 2,500+ miles (cross-country or international).
    • Above 35° to 40° (Too High): At 27 MHz, signals aimed too steeply upward usually punch straight through the ionosphere into space rather than bouncing back down.
Quick Summary by Contact Type
Contact TypeDistanceIdeal Takeoff AngleHow Your Design Performs
Local0–40 miles0° – 10°Strong horizon punch (improves with height)
Regional / Medium Skip600–1,200 miles15° – 25°Peak lobe zone for 22.5° drooping radials
Long-Distance DX1,500–2,500+ miles5° – 12°Good low-angle lobe, especially mounted 1+ wavelength (~36 ft) high
(Note: Raising the feedpoint closer to 36 feet—one full wavelength above ground—helps pull your main radiation lobe down toward that lower 10°–15° range, boosting both local range and long-distance DX at the same time.)
Would you like to look at:
  • How mounting height (e.g., 20 ft vs. 36 ft) shifts the takeoff angle on 11 meters
  • How to build a simple coaxial choke to keep feedline radiation from distorting this pattern
  • Step-by-step SWR tuning once you get the antenna mounted?
For your boat, you can run a mobile antenna as long as you have a ground plane like a metal canopy.
As far as the dipole antenna is concerned, I like my 1/2 wave. It works very well.
Best of luck getting on the air. You have made some conservative choices that you should be happy with.
Reactions: petehdgs
The Little Will antenna is barely adequate. It will get you on the air but won't get out very far, less than 5 miles. you would be better off with a 5 foot antenna or taller. with cb the taller the antenna the better up to a certain point.
I agree,I've used a Little Will in the past and wasn't impressed with the performance , I much prefer the Wilson 500 or 1000 mag mount antenna as I've used both in the Past and both worked well for me with great results,jmo............
Reactions: VMC and petehdgs
