Cushcraft Issues
Mudfoot
Elmer
Jun 17, 2009
10,919
6,296
698
62
Southeast Ohio
Bought a 4 element dual band yagi. I have little gripe about the actual antenna, but the phasing harness is crap.
They use super cheap crimp on connectors that won't allow the center conductor to fully seat, which allows slop. The outer shell has a brass looking retaining clip which holds the out shell on. If you try to tighten to remove the slop, the ring snaps.
I had to replace all 4 connectors. This might be why eham flunkies are griping about SWR and tuning issues. Once fixed, the antenna required no tuning and works as I hoped. I'm using this yagi for fixed purposes.
I'm getting ready to order the 10 element dual polarity beam for regular CW/SSB use with a rotor on my hillbilly rooftop tripod contraption since it requires two feeds, I won't have to worry about junky connectors.
that harness was garbage 20 years ago when i got mine.
ended up making my own after the second replacement under warranty.
i do not remember the details but there are critical lengths to measure.
i would have thought this would have been fixed long ago.
letting defects go out the door for years driven by beancounters leads to failure and acquisition by mfj for pennies on the dollar.
Reactions: Mudfoot
  • @ Wildcat27:
    63Sprint has left the room.
