Have you opened it up to take a look inside yet...
Taking a good set of high quality good focused pictures can help you in finding problems you will have to repair - just use your phone - keep them in a folder or your photos and review them, zoom in, pan around...
You say it's an old Cobra 25, well - how old - is old?
If you can, you can locate the approximate year it was made, they're printed inside - on one of the chips the Radio has.
The Big rectangle one with all the pins on it - that should be the PLL - it's over by the channel selector.
This is a similar but not exact board...
There's a name, Manufacturer, and type of chip - and then the Date Code
97 - refers to Year circa 1900's - 1997 - 9 month 2nd week. In the one above...
If the '25 is really old, it may need a lot of things needing to be done - replaced - like that big black round can right next to the one in the above photo, it's an electrolytic - it filters the power supply feed to this chip - you'll have similar in yours.
You can also look for similar board radios like the TRC-427 or the Uniden PC-66 or PC-68 - they use similar design - to help you get started.
Just use the Search Box in the upper right corner and look for say PC-66 no RX you'll find quite a few threads out there.
Good luck and be patient...
