I have several Anytone radios and the stock microphone is the best on all of them.
It is the shorter board, I'll post some pictures in the next day or two, I'm thinking there must be different versions/updates to this board.Tim hasn't logged in since the end of last month, but I am sure that he will respond as soon as he sees it. Your Ares 2 should have the new short board in it. It is supposed to be similar to the new version of the 955, the new 5555 and new 5555n2 and a few others. But apparently different enough still.
Only a tad over 100% modulation is possible without distortion on the ARES 2. You must make sure that NPC is OFF if you are trying to align for a clean 100%. With NPC ON, a lot of the service modulation adjustments seem to be bypassed, or they behave very strangely. (FYI, more microphone drive/gain won't help as the radio already has enough gain in reserve using the stock mic.) I trust that you are using a scope with high enough bandwidth, and have the required test equipment to set these things correctly.Sorry for my impatience, I don't see how people have acheived over 100% modulation on a stock mic as I have tried all the adjustments and a power mic, has anyone done any firmware mods for any of thesr type radios?
It's actually getting pretty close IMO, especially given the huge price gap!I have a couple of Anytone radios, one uhf and the other vhf (1.25cm). They both work great but honestly the build quality is nowhere near the big three (Icom, Yaesu, and Kenwood)
When you say "outperforming in every way", do you mean specifically the power output, and AM modulation percentage? Because that is the only two things that the 6666 has over the ARES2/QT40, in terms of "performance" that I have measured in all my testing. I know, those two things matter a lot to some, so I'm not arguing that, just pointing out what I have measured. FYI, I would choose the RX on the ARES2/QT40 over the 6666 every time. I find the 6666 hard to listen to after coming back to it from an ARES2 or 5555Nii. What are your thoughts on the RX?I own several Anytone radios. I have the tiny "Smart" CB-40, The AT-500M, The old version Quad 5, The Quad 6, and the Radioddity QT40.
I want the QT40 to be my permanent base station rig, but the Quad 6 is outperforming it in every way. I wish I knew a way I could just bring the modulation up on the QT40, but I will have to wait until that information becomes available.
I also own Uniden, Cobra, Realistic, and President radios, but even my Anytone AT-500M blows all of them away.
There's a quirk to get it. If you just hold the buttons and power on, it won't do it. You have to start with the radio on, then click it off, hold the buttons, and right back on before it's done powering down. If you let it power completely down, it won't work. At least that's the experience I had with mine.My Anytone ares 2 will not go into service menu with the combination as explained above and no cigar.
The RX on the Radioddity QT40 is better than the Quad 6, but I have 50 to 130 miles contacts we do nightly and everyone says the Quad 6 is better as far as modulation and transmit.When you say "outperforming in every way", do you mean specifically the power output, and AM modulation percentage? Because that is the only two things that the 6666 has over the ARES2/QT40, in terms of "performance" that I have measured in all my testing. I know, those two things matter a lot to some, so I'm not arguing that, just pointing out what I have measured. FYI, I would choose the RX on the ARES2/QT40 over the 6666 every time. I find the 6666 hard to listen to after coming back to it from an ARES2 or 5555Nii. What are your thoughts on the RX?
Interesting, and all good on the RX. I wouldn't trust that old modulation meter though! (I think many old-school modulation meters would be better named "distortion meters"!)The RX on the Radioddity QT40 is better than the Quad 6, but I have 50 to 130 miles contacts we do nightly and everyone says the Quad 6 is better as far as modulation and transmit.
In my heart, I feel that even though the power output is less on the QT40 compared to the Quad 6, the QT40 would make up the difference if the modulation was better. My 4 stage old school meter shows like 20% modulation on my QT40. I have old school radios that put out 100% and sound better.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
