take a look at the early 2950 service manual. it has voltage charts that should help you out checking your radio.
http://www.cbtricks.com/radios/rci/rci_2950/index.htm
did you look at this voltage chart?
http://www.cbtricks.com/radios/rci/rci_2970/rci2970_trvolt_chart.htm
Yes, I spent a fair amount of time looking at the voltages mainly the oscillators and mixers but the transistors being used are different. Some oscillators are ICs. I found a schematic for the RCI 5054 which uses the same mc146162 pll but it too has no voltage chart.
At any rate the problem appears to be VCO 1. According to pll alignment instructions, vco1 should be the frequency displayed 28.000 plus the 10.695 to get 38.695. However TP 3 reads 35.225. Subtract the 10.695 and you get 24.530. That is 3.470 below the frequency displayed. My plan now is to hunt down whatever is supposed to generate the 10.695 and the 28.000 and check the active and passive components. Hopefully I can figure out why vco1 is not working properly.
Lots of shields to remove before I can get at the pll transistors. Maybe too much heat to do it in one go. I attached the schematic for RCI5054 so any one wants to help can take a look at it.
haven't read through the whole thread but these radios are notorious for having badly manufactured tuning coils. also some of the tuning coils have a small capacitor internal to them that can go bad.
If you notice any cans around the pll area that either dont show a peak, or show a peak with the ferrite slug flush with the top of the can, then you probably have a bad tuning coil and need to replace it.
best of luck.
LC
I wonder if a DDS VFO would work?Resurrecting an 8 year old thread. I just had a 2950DX on the bench that had the same symptoms. I removed the PLL IC, and checked both VCO's by applying a low voltage to each VCO, and both were working correctly. I traced it down to corrupted data coming out of the microprocessor. The data is not communicating with the RX Phase Detector. Also there should be 10.100 MHz at TP16 which there was not. But the 10.100 MHz oscillator was also working correctly. The radio made it way to the parts bin, as the CPU boards are un-obtainium.
That would not work in this particular radio.
That would require firmware from RCI, which I doubt you could get. Plus you would need a programmer/hardware for the HD4074818 microprocessor.Are the inputs and outputs for those CPU's written down anywhere? If we can't get the original parts maybe we can emulate them.
It would have to be approached as black box reverse engineering project. The same way Mark Rutherford (Mark19960 on YouTube) approached the Uniden 980SSB replacement control board he designed and briefly sold. But it is doable. Whether or not the result would fit inside the 2950DX case is a different problem.That would require firmware from RCI, which I doubt you could get. Plus you would need a programmer/hardware for the HD4074818 microprocessor.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
