AI strikes again.
Naysayer
Solder Balls
I Support WorldwideDX.com!
Mar 6, 2020
337
259
New York
I don’t have as much electronics equip & tools as most Members but, it’s a lot. So when the relatively new Garment Steamer stops working, it looks funny if I can’t fix it. I need a thermal switch & all I need do is find one. Illegible Part # no help from Pur.
So I try AI for the 2nd time. There’s hundreds of switches. AI requested the make, model, etc. AI then searched eBay based on specs collected.
I have too much time into this steamer and AI is starting to make sense. Am I late to Co-Pilot for finding parts? It’s more helpful than I imagined. ‘Parts apprehension’ always. Making sense here?
Reactions: Naysayer
Might want to double check the part number. The KSD301-X comes in multiple flavors. Normally open and normally closed. Amazon sells both. I would sure think that device would use a normally closed switch that opens when too hot.
I could be wrong, just double check what it needs. Seems there are more normally open switches available. Now sure how that thing is wired though.
Mystery solved over Normally Closed vs Normally Open.
The Part marking convention is denoted by whether the terminals are Bent/Straight and by the color of the insulator: Bent foot w/ white insulator is Normally Open.
Straight foot w/ black insulator Normally Closed.
My problem was that the part # was worn away.
