Heathkit HO-10 Monitor Scope for HF
Naysayer
Solder Balls
I Support WorldwideDX.com!
Mar 6, 2020
361
271
New York
Got this from eBay a weeks or 2 ago. Ordered new caps and some select resistors. Input adjustable rear panel from 1/2w to 1kw (SSB I presume) just a jumper with a signal tap to scope inputs.
It's old but limited features so it's not so complicated I'd avoid using it. Will it have "use value" or just a pretty green light? IDK but I'll get it set per the manual and see.
Inside was in good shape all stock w/ some evidence of smoking environment. Orig Builder did a fine job with the solid PTP wiring, purposefully bent leads. Reluctant about replacing everything. Vertical gain pot (1MO) somehow destroyed, shaft would not turn, inside wiper broken/bent somehow. My 1st project since getting new LCR meter so it’s an opportunity learn using it. HO-10 Monitor Scope pic.jpg
All tubes tested good.
That sure works in your favor. Seems to me there's a 12-pin "compactron" tube in there, maybe a 6C10 that has three triodes in it. Saves space, but that one has gotten expensive. Turns out to have been used in some high-end guitar amp of the 60s.
I used one of these decades ago. Decided to set up a FT-101 (no suffix letter) at home when the kids were young. None of them got really interested, but found I couldn't tune up a radio without a 'scope. Always had one on hand at work for decades. Took one of these home after a re-cap and it fixed my problem, especially for RTTY. Made tuning the receiver a lot better. It went onto the shelf a while later when the FT went back to work as a bench radio. A later-version SB610 came in for service and needed a CRT. Tried to unplug mine and the lead wires came out of the hollow pins at the base of the CRT. They had rusted/rotted out over the years.
Oops. But I located a new CRT for the customer so he went home happy. Pretty sure the sad HO-10 with the ruined CRT base is still hiding in a corner waiting for doomsday. Anybody want one, cheap?
Reactions: Naysayer
Nearly a Month later, got the new parts installed into scope but have not yet applied power. I planned on replacing every resistor pair (same value) only. After I measured a few, it was obvious they all need replacing. They all show far higher resistance than their color band values (like: 330k being over 400k), So I am using lots of braid. Replaced another Pot that was jumpy and rebuilt another to restore smooth operation. Not much space inside.
Oh right, got my General CSCE last night. Tested in-person at a GLAARG site in Brooklyn sponsored by the NYC Resistor collective. Never went there before but they have a nice space/workshop area. I am eager to use new privileges but need to wrap up the scope before I start something else or I'll forget what goes where.
I downloaded the condensed manual (HO-10 Monitor Scope) but there are no wiring instructions. Was there a separate Assembly Manual? I recall such instructions in older kits I had in the early 70's. Original Builder made frequent use of unused tube-socket pins as connecting posts for unrelated wires/components. Efficient yes but 5 decades later, confusing AAF. The manual available online lists the parts, operation of scope, diagrams and trouble-shooting but nothing about assembly.
Diagram Convention Question
Where the diagram shows connections and/or wires heading off-page with a note (like: "B+ Hi 380v") that means it connects to any other place on the diagram where the same note appears, right?? If it was a Test Point, it would say so. This design is likely older than I am.
Just want to work 40M as soon as I can move scope off work table.
later, neil
@Naysayer
I don't know if this is what you're looking for, but I hope it helps......
I've also enclosed a picture of an HO-10 with different knobs, they are what I use on mine.
The HO-10 originally sold for $16.00 if I recall, when new in the early 60s, and what is left out there today are worth having just for parts. I've had transformers burn out, high voltage caps go bad, and I keep a supply of tubes just for my needs.
I have three working units. In order to keep the screen from getting a burn across the middle, run the "Intensity" as low as you need to view it.
You should have a "High Voltage Probe" on hand (if you don't have a DMM that will measure that high) just for testing the -1550v from tube "V6" (1V2) when it goes there is no display.
The "6C10" (tube V3) can be hard to find sometimes due to the use in guitar amplifiers. I just hope that they are still out there
Keep your hands clear of the inside if you have it turned on while testing.
I have found the following online:
Dr. Frankenstein,
That manual is exactly what I needed. A huge thank you for the Assembly document. I looked everywhere and could not find it. I've been using pics which relies on orig builder and often fails to capture what I need a day or 2 later.
Trying to stay away from the two, one-piece filter networks (Sprague 84-22) which are no longer made (found article on how to fabricate internal circuit and it looks very tedious.
I replaced nearly every resistor. The value deterioration is the worst I've ever seen as if the originals were factory rejects. I do have HV probe. I'd like to replace the original diodes (doubler) with 1N5404's or do I need something else?
AND ....... That QST article is the bomb! Circuit upgrades for a 60 year old device. This forum has unbelievable depth in it's Human resources.
Thanks again. neil, n2eye
That Assembly Manual really helping. I'm going step by step to verify all connections. Initial attempt to perform pre-power test measurements failed 1st step: Measure resistance btwn Ground & lug/pin 1 of V6 (Rectifier tube plate, IV2). It's lower than it should be by MO's (should be approx. 5 MO). Checking Intensity pot/switch (already found 2 bad pots) and the scariest of all, transformer. All of this was not possible without the Assembly Manual, again thanks for that doc. My tubes all tested OK but it's a tedious process.
I'll post again ...... likely far more than I should.
My timing of starting this project was not the best. Wanted to take General exam for several months but could not find an in-person site and when I did, I had already begun scope tear-down. Now it's stopping me from using new General privileges because if I start operating now, the distraction will put the scope in my closet indefinitely. Good motivation, I guess.
I think I made a mistake via my misunderstanding of Metering. I may have figured it out but I’m looking for corroboration. The Heathkit build instructions have 3 measurements of Resistance that should be attained prior to applying power for the first time.
My first measurement was far too low by a magnitude of a few MO’s. I used an LCR meter that uses an AC signal. After a day of chasing my tail I now suspect the LCR meter's AC sampling included all the bypass caps which gave me such a low reading. Is this logical and reasonable?
So I need another VOM in addition to the LCR?
Is my thinking correct here?
another VOM
The meter that was used to obtain the numbers in the Heath manual would have been one of their VTVM models, most likely. Used a 1.5-Volt flashlight cell to power the Ohms scale. You need a meter that uses DC to measure resistance when comparing to the manual's numbers. Worn-out front-panel potentiometers are the bane of old analog 'scope maintenance. The high voltages tend to wear them out.
Reactions: Naysayer
Thanks Nomad, this issue had me flummoxed for a bit. This morning I got the scope working to extent it passed the manual's section of "Test & Adjustment". Everything seems to be working fine. Dr Frankenstein, thanks again for the Assembly manual.
Reactions: Dr. Frankenstein
