Super basic arduino nano data logger (linux)
brandon7861
Loose Wire
I Support WorldwideDX.com!
Nov 28, 2018
2,684
2,985
293
Not sure if this is the right place to put this, but I thought others may find it useful. This is for linux and I have no idea how to do it in windows. Next year, when I forget how to do this and AI costs too much, this will hopefully be here.
A coworker picked me up some cheap AA batteries and I want to compare them to energizers, so I figured I would make a constant current load and monitor the battery voltage over time. I don't have a data logger, but a nano has an ADC input and a USB port. This is how to send the ADC voltage to a CSV file in linux.
Upload this to a nano:
const float ADC_REFERENCE = 5.00;​
void setup() {​
Serial.begin(115200);​
void loop() {​
int raw = analogRead(A0);​
float voltage = raw * (ADC_REFERENCE / 1023.0);​
Serial.println(voltage, 4);​
delay(1000);​
The ADC_REFERENCE is the 5v supply (your USB cable voltage). USB hubs can drop voltage. Mine was 4.6v and it has a big affect on accuracy so measure it and enter your actual supply voltage here (just measure between GND and 5v on the arduino pins and put that where 5.00 is). A0 is the ADC pin it is measuring. Its a 10 bit ADC which is where 1023 comes from, its the number of discrete levels it can detect. The 4 after voltage is the number of decimal places it displays. The delay is how often it sends data to the computer in milliseconds. Speeds are limited my ADC clock and USB speeds.
Now close it. You don't want the IDE open when you run the logger and you don't want the logger running when you try to program the nano.
Install the python serial comms package
sudo apt install python3-serial​
You should already know this from the arduino IDE, but see what USB port the nano is on
ls /dev/ttyUSB* /dev/ttyACM*​
You should see something like "/dev/ttyUSB0". Remember that for the python script.
Make a datalogger directory under your user home dir (or wherever)
mkdir -p ~/data_logger​
In that folder, you gotta add a little python script. Start by making the file.
nano ~/data_logger/logger.py​
That should open the editor. Paste this in with ctrl+shift+v making sure to get the port right.
import serial​
import csv​
from datetime import datetime​
import os​
PORT = "/dev/ttyUSB0"​
BAUD = 115200​
FILE = "data.csv"​
ser = serial.Serial(PORT, BAUD, timeout=2)​
file_exists = os.path.exists(FILE)​
file_empty = not file_exists or os.path.getsize(FILE) == 0​
start_time = datetime.now()​
try:​
with open(FILE, "a", newline="") as f:​
writer = csv.writer(f)​
if file_empty:​
writer.writerow(["timestamp", "elapsed_seconds", "voltage"])​
f.flush()​
print("Data logger started.")​
print("Writing to:", os.path.abspath(FILE))​
print("Press Ctrl+C to stop.\n")​
while True:​
line = ser.readline().decode("utf-8", errors="ignore").strip()​
if not line:​
continue​
try:​
voltage = float(line)​
except ValueError:​
continue​
now = datetime.now()​
elapsed = (now - start_time).total_seconds()​
writer.writerow([​
now.strftime("%Y-%m-%d %H:%M:%S"),​
f"{elapsed:.1f}",​
f"{voltage:.4f}"​
f.flush()​
print(​
now.strftime("%H:%M:%S"),​
f"{voltage:.4f} V",​
f"({elapsed:.0f} s)"​
except KeyboardInterrupt:​
print("\nLogging stopped.")​
finally:​
ser.close()​
Then save (ctrl+o then Enter) and exit (ctrl+x)
To start logging, use this:
cd ~/data_logger​
python3 logger.py​
and to stop logging, use ctrl+c
Terminal will look like this:
and the csv looks like this:
Note how in this test it was reading 0.4596v. I had the ADC pin floating when I did this. Don't expect it to show 0v unless it is actually connected to something that is at 0v. Also, you need to keep it within the nano's supply voltage so resistively divide and scale as appropriate. A zener to absorb spikes and a 1k resistor wouldn't be a bad idea either.
Now I need to make a constant current load and kill some batteries. I'm guessing 100mA is a good starting point. I have this bad habit of starting new projects when others are still incomplete lol
I've made some minor improvements if anyone is interested. I will leave the basic version up there and put the better version here.
The new version works like this. Run the python (logging will not start). It does a handshake with the nano and uploads the configuration to the nano so you can change things like supply voltage and new features without reprogramming it each time. The config file looks like this (saved as config.txt in same directory as logger.py):
AUTO_START_ENABLED=false
START_VOLTAGE=2.00
AUTO_STOP_ENABLED=false
STOP_VOLTAGE=1.00
SAMPLE_INTERVAL=1.0
SOUND_ENABLED=true
ADC_REFERENCE=5.11
NEW_FILE_EACH_START=true
Bringing D2 low starts and stops the logging. The configuration allows you to set an optional start and stop logging based on voltage. Less than the stop voltage stops logging and higher than the start voltage starts logging. It also has an option to start a new file each time or to add to the previous file. And if auto stop is set, it has the option to play a notification sound.
code got really long so I will put it in a spoiler.
const int VOLTAGE_PIN = A0;
const int CONTROL_PIN = 2;
// DEFAULT SETTINGS
float adcReference = 5.11;
bool autoStartEnabled = false;
bool autoStopEnabled = false;
float startVoltage = 2.00;
float stopVoltage = 1.00;
unsigned long sampleInterval = 1000;
bool soundEnabled = true;
// LOGGER STATE
bool logging = false;
bool lastButtonState = HIGH;
bool stableButtonState = HIGH;
unsigned long lastDebounceTime = 0;
unsigned long lastSample = 0;
// CONFIGURATION RECEIVER
void receiveConfig() {
String line;
// Tell computer we are ready
Serial.println("READY");
while (true) {
if (Serial.available() == 0) {
continue;
line = Serial.readStringUntil('\n');
line.trim();
if (line != "CONFIG") {
continue;
// Receive configuration
while (true) {
continue;
line.trim();
if (line == "END_CONFIG") {
break;
if (line.startsWith("AUTO_START_ENABLED=")) {
autoStartEnabled =
line.substring(19) == "true";
else if (line.startsWith("START_VOLTAGE=")) {
startVoltage =
line.substring(14).toFloat();
else if (line.startsWith("AUTO_STOP_ENABLED=")) {
autoStopEnabled =
line.substring(18) == "true";
else if (line.startsWith("STOP_VOLTAGE=")) {
stopVoltage =
line.substring(13).toFloat();
else if (line.startsWith("SAMPLE_INTERVAL=")) {
float seconds =
line.substring(16).toFloat();
sampleInterval =
(unsigned long)(seconds * 1000.0);
else if (line.startsWith("SOUND_ENABLED=")) {
soundEnabled =
line.substring(14) == "true";
else if (line.startsWith("ADC_REFERENCE=")) {
adcReference =
Serial.println("CONFIG_OK");
return;
// SETUP
void setup() {
pinMode(CONTROL_PIN, INPUT_PULLUP);
delay(1000);
receiveConfig();
// LOOP
void loop() {
// BUTTON
bool reading = digitalRead(CONTROL_PIN);
if (reading != lastButtonState) {
lastDebounceTime = millis();
lastButtonState = reading;
if ((millis() - lastDebounceTime) > 50) {
if (reading != stableButtonState) {
stableButtonState = reading;
// Button pressed
if (stableButtonState == LOW) {
if (!logging) {
Serial.println("START");
logging = true;
lastSample = millis();
} else {
Serial.println("STOP");
logging = false;
// READ VOLTAGE
int raw = analogRead(VOLTAGE_PIN);
float voltage =
raw * (adcReference / 1023.0);
// AUTOMATIC START
if (autoStartEnabled &&
!logging &&
voltage >= startVoltage) {
logging = true;
// LOGGING
if (logging) {
unsigned long now = millis();
if (now - lastSample >= sampleInterval) {
lastSample = now;
// AUTOMATIC STOP
if (autoStopEnabled &&
voltage <= stopVoltage) {
if (soundEnabled) {
Serial.println("SOUND");
logging = false;
import serial
import csv
import os
import subprocess
import time
import glob
# FILES AND SERIAL
BAUD = 115200
BASE_DIRECTORY = os.path.expanduser("~/data_logger")
CONFIG_FILE = os.path.join(BASE_DIRECTORY, "config.txt")
LOG_DIRECTORY = os.path.join(BASE_DIRECTORY, "logs")
SOUND_FILE = os.path.join(BASE_DIRECTORY, "notify.mp3")
os.makedirs(LOG_DIRECTORY, exist_ok=True)
# READ CONFIGURATION
def read_config():
config = {}
with open(CONFIG_FILE, "r") as f:
for line in f:
line = line.strip()
if not line or line.startswith("#"):
continue
if "=" not in line:
continue
key, value = line.split("=", 1)
config[key.strip()] = value.strip()
return config
# SEND CONFIGURATION TO NANO
def send_config(ser, config):
print()
print("Sending configuration to Nano...")
ser.write(b"CONFIG\n")
ser.write(
f"AUTO_START_ENABLED={config.get('AUTO_START_ENABLED', 'false')}\n"
.encode()
ser.write(
f"START_VOLTAGE={config.get('START_VOLTAGE', '2.00')}\n"
.encode()
ser.write(
f"AUTO_STOP_ENABLED={config.get('AUTO_STOP_ENABLED', 'false')}\n"
.encode()
ser.write(
f"STOP_VOLTAGE={config.get('STOP_VOLTAGE', '1.00')}\n"
.encode()
ser.write(
f"SAMPLE_INTERVAL={config.get('SAMPLE_INTERVAL', '1.0')}\n"
.encode()
ser.write(
f"SOUND_ENABLED={config.get('SOUND_ENABLED', 'true')}\n"
.encode()
ser.write(
f"ADC_REFERENCE={config.get('ADC_REFERENCE', '5.11')}\n"
.encode()
ser.write(b"END_CONFIG\n")
ser.flush()
deadline = time.monotonic() + 5
while time.monotonic() < deadline:
line = (
ser.readline()
.strip()
if line == "CONFIG_OK":
print("Nano configuration accepted.")
return True
print("ERROR: Nano did not acknowledge configuration.")
return False
# PLAY SOUND
def play_sound():
if not os.path.exists(SOUND_FILE):
print("Sound file not found:")
print(SOUND_FILE)
return
print("Playing notification.")
try:
subprocess.Popen(
"ffplay",
"-nodisp",
"-autoexit",
"-loglevel",
"quiet",
SOUND_FILE
stdout=subprocess.DEVNULL,
stderr=subprocess.DEVNULL
except Exception as e:
print("Could not play sound:", e)
# FIND MOST RECENT LOG
def find_last_log():
files = glob.glob(
os.path.join(LOG_DIRECTORY, "data_*.csv")
if not files:
return None
return max(
files,
key=os.path.getmtime
# OPEN LOG
def start_logging(new_file_each_start):
if new_file_each_start:
timestamp = datetime.now().strftime(
"%Y%m%d_%H%M%S"
filename = os.path.join(
LOG_DIRECTORY,
f"data_{timestamp}.csv"
mode = "w"
else:
filename = find_last_log()
if filename is None:
"%Y%m%d_%H%M%S"
LOG_DIRECTORY,
mode = "w"
else:
mode = "a"
log_file = open(
filename,
mode,
newline=""
writer = csv.writer(log_file)
# Add header only to a new file
if mode == "w":
writer.writerow([
"timestamp",
"elapsed_seconds",
"voltage"
log_file.flush()
print()
print("===================================")
print("LOGGING STARTED")
print("File:", filename)
if mode == "a":
print("Mode: APPENDING")
else:
print("Mode: NEW FILE")
return log_file, writer, time.monotonic()
# MAIN
ser = None
log_file = None
writer = None
start_time = None
try:
config = read_config()
new_file_each_start = (
config.get(
"NEW_FILE_EACH_START",
"true"
).lower() == "true"
print("Data logger")
print("Configuration:", CONFIG_FILE)
PORT,
BAUD,
timeout=1
time.sleep(2)
# Wait for Nano READY
print()
print("Waiting for Nano...")
ready = False
line = (
ser.readline()
.strip()
if line == "READY":
ready = True
print("Nano is ready.")
break
if not ready:
raise RuntimeError(
"Nano did not send READY."
# Send configuration
if not send_config(ser, config):
raise RuntimeError(
"Nano configuration failed."
print()
print("Waiting for START...")
print()
# MAIN SERIAL LOOP
while True:
line = (
ser.readline()
.strip()
if not line:
continue
# START
if line == "START":
if log_file is None:
log_file, writer, start_time = \
start_logging(
new_file_each_start
continue
# STOP
if line == "STOP":
if log_file is not None:
print()
print("LOGGING STOPPED")
log_file.flush()
log_file.close()
log_file = None
writer = None
start_time = None
continue
# SOUND
if line == "SOUND":
play_sound()
continue
# VOLTAGE
try:
except ValueError:
print(
"Unknown Nano message:",
line
continue
continue
elapsed = (
time.monotonic() - start_time
"%Y-%m-%d %H:%M:%S"
writer.writerow([
timestamp,
f"{elapsed:.1f}",
f"{voltage:.4f}"
log_file.flush()
print(
timestamp,
f"{voltage:.4f} V",
print()
print("Data logger shutting down...")
print()
print("ERROR:")
print(e)
finally:
log_file.flush()
log_file.close()
if ser is not None:
ser.close()
print("Data logger stopped.")
