Stryker 955 NPC/swing mod
Yes, you can.
C68 is the spot you connect 100 Ohm/1n4148 combo. As marked on the attached image.
Also I would disable AM limiter, NPC will take care about it. Remove R27 for that.
Mike
Question : when doing an NPC mod on a 955 , do you need to remove C68 or leave it in place ??? Question #2 are the results any good ? I’ve done NPC mods before, some work well on certain radios
Instead of hacking the radio for more average power... Just get an amp
I agree. I purchased two 955HPC+ radios at the same time and both radios have been working great for one year. No mods on either radio and the Low Dead-Key is 1.5 watt and High Dead-Key is 8 watts. My friend bought one radio from me and we both have a 2-pill amp driving a 10-pill amp. We keep the dead-key out of the 10 pill at 200 watts.
Trying to do the mod to my lincoln ll plus and the board looks a little different. Will the mod work on mine? Also where is d 28?
