You've never really seen it all. Final transistor with RTV silicone....
nomadradio
Analog Retentive
I Support WorldwideDX.com!
Apr 3, 2005
9,027
15,177
698
Louisville, KY
www.nomadradio.com
Just when you think you've seen everything.
Found a bad final transistor in a RCI2990DX. There was no heat sink compound between the ceramic insulating washer and the heat sink. But the washer was glued to the transistor with white bathtub caulk. I guess somebody told the weekend warrior to put some silicone on the new part when installing it. A tube of RTV rubber in the hardware store will clearly say "silicone" on the package.
Looks like I should have backed the camera away and zoomed in more. Depth of field isn't quite right here.
This was clearly a counterfeit transistor. Has the Mitsubishi "three diamonds" logo, but the package is the wrong size. A Mitsubishi part would be 9 mm wide. This one is the standard 10mm everybody else uses for this type package. Doesn't mean it was a bad part. It's a counterfeit that worked, or so said the customer.
Until the heat caught up with it.
Somebody should have explained to this guy what kind of silicone to use. And where to put it, for that matter.
Geez o_O
There must be a fanbase of RTV.... I've had a rash of (some not-so-cheap) stereo's last couple months on the bench half-potted in the stuff where there wasn't duct tape.
I dealt with it in a few early PLL encapsulations of the 858 type. At least that was better than using epoxy, tar, or corrosive glue. An Exacto blade cut around the old caps made their replacement less difficult.
I found that JB Weld has good thermal conductivity.
I used it to glue TO-220 transistors to a piece of aluminum for a heat sink,
for some transmitter modulators and power supplies I was designing.
I also worked at a place (TEKIN) that made motor controls for competition
grade RC race cars, and the 6 MOSFETs were glued to the heatsink
with a two-part epoxy resin compound.
fast and easy to mount to a heat sink.
I do not know how the resin mix would work at RF and with higher voltages.
also, that W8JI guy on his website has his test of using pure silicon grease
(usually marketed as "Dielectric Grease") as a heat sink compound.
He was using the Permatex Dielectric Tune-Up Grease. (??)
