Anytone AT-5100
That's a decent price for a capable radio if it follows in the footsteps of the other QT radios.
It will mate well with the 2 pill texas star amps I have and as you can see in the video above it looks to be a very capable radio.
I kind of like the anytone silver faceplate a little better than the radioddity version.
The qixiang guys are really pumping out radios and thankfully they're doing it before the cycle falls flat on 11 meters.
Hadn’t considered the radio until I saw the Radioddity version, since I prefer a black faceplate. Ordered from Radioddity directly and was able to use a coupon code of RO14TH
which brought the price of the radio to $143.65. I think that code may expire at the end of August 2026.
Looking to replace my Moonraker Titan Mk II (aka Chierda S-890) with the QT30, since the QT30 has all the features the Titan Mk II lacked.
I just received the radioddity version (qt30) last night but didn't have a chance to even open the box. With lot's of great reviews on this one I'm hoping to have a winner. I'll update with my thoughts after I crack open the packaging.
I'm thinking it will pair nicely with a Texas star 250 or 350 but we'll soon find out.
Have a QT30 from Radioddity. Nice Radio, but mine is 30hz off frequency. Radioddity told me not to have a way to correct this. 30hz is within tolerance, so no reason to fix it, but I know it can be better.
There must be a hidden Service Menu to correct the issue, but nobody knows how to enter the Service menu.
  • Wow
Reactions: TM007 and BC Coyote
That's inexcusable! I won't be buying one of those that's for sure! It points towards poor quality control which is usually RCI's department.
It also makes me super hesitant to buy anything else branded "Radioddity".
Can the service settings be accessed with the Anytone 5100 software available from the Anytone website?
Tried mine out today and it's definitely a keeper. Made several contacts from the garage on the attic dipole and received several unsolicited compliments on the audio and questions asking about the radio. Excellent for the price!
One dislike though but not a big deal. I'll have to make sure it's not user error but the nrc has levels on both tx and rx which the nr is great but the on off turns both on or off and not independently. On my other radios I don't use tx noise reduction but I do for rx. On this one i set tx to 1 because I doesn't turn off. It seems fine so it's probably a petty gripe.
Aside from my gripe, it's a touchdown!
So it's not a new radio then is it? It's a re-release of an old radio with a different companies name on the case. Looks like it's been released as a Cobra, Magnum, and about a dozen others already. I'm guessing Qixiang is the manufacturer of all those as well then?
That's been the "export" game plan for a long time now
Day 2 of using it and it's an ssb performing radio no doubt. You've probably already seen the innards but I'll add some close up photos here for anyone needing them for reference in the future.
Not a full scale review but on the autek wm-1 into a dummy load it produces about 35 to 40 pep depending on the voice peaks in ssb. Heat is no issue with the large heatsink it has. Impressive for a little rig of its size. I'm moving it into the station room and will be driving a Texas star dx-399 with it this week to see how it plays.
More to come
20261108_174114.jpg20261108_174117.jpg20261108_174140.jpg20261108_174146.jpg20261108_174151.jpg20261108_174200.jpg20261108_174216.jpg20261108_174529.jpg
