Source for Galaxy DX Band Boards
DTB Radio
Well-Known Member
Sep 14, 2005
1,124
242
Carlisle, PA. USA
www.dtbradio.com
I'm in need of some replacement band boards for the older Galaxy DX88HL (and similar-chassis) radio. I've exhausted the used/repaired ones I had, and I've not found a source that has current stock in my online searches. There was one outfit selling a universal replacement for both the older and newer boards, but I can't find them, either. Any help appreciated/.
Your too late! Everyone is retiring or dieing! I am sure you and I used to use the same suppliers that are no more.
Not trying to be a smart arse either I too can no longer find what I need.
One place I used to use sold and part of it's inventory went to one guy and all of the Browning stuff when to another guy. Last I checked neither seemed too interested in actualy selling what they had. I understand that it takes time to set tings up but it has been a while.
You would think that is Galaxy and RCI where interested in selling parts someone would have moved to be a distrubution point/supplier but I have not seen anything materialize!
Covid-19 seems to have broken everything electronic even a lot of jelly bean parts are hard to find now!
If you hear anything it sure would be nice if you passed the info on. I will do the same! God Bless!
Brian at trucks took the reigns of barkett and he has a pretty good relationship with the guys at ranger. He like Greg used to do can have ranger send what's available if Brian doesn't have any.
The kicker is the cost though.
The universal 8-band board was branded "Black Adder" IIRC. It had both types of header pins to replace either original or newer type board. It popped up almost 20 years ago and disappeared soon after. Pretty sure the instruction sheet made it onto CB Tricks. I toyed with the idea of making a replacement using a microcontroller. But the pin count feeding into and out of it got the better of me. Never progressed beyond a schematic. Which version of the board are you trying to find?
