Medco "Delta-scan" received with radio, Have a look ! 8-))
Michael M
May 17, 2019
31
21
18
58
Hello all,
with a recent purchase, I received a Medco "Delta-scan", made by Merit Electronic Design Co. of Huntington NY (according to the label on the back). A friend of mine had a Realistic TRC-449 with a "Digi-scan" back in the day (which I always liked).
Since I am starting to clear the radio, I thought it would be fun to post some pictures of the "Delta-scan" unit. It's really a blast from the past of digital electronics!
If anyone has any information on the delta-scan unit (manual, history, experience, ect), please post!
Thanks,
Solder side, under the ribbon socket:
The flat cable tells you it's a digital channel selector. Wires in place of the radio's channel selector. Doesn't have its own PLL like the Redco digiscan. The digital output might be right for the BCD codes used in the uPD858, or pure binary like the MB8719. Or MC145106. Or PLL02A. FIguring out which one is a bit tedious ,but doable.
The Redco came with my (somewhat dead) Realistic TRC-457 (upd858). The Redco control pins change/act according to the 858 truth table from 26-28 Mhz, but the 858 in the rig is bad. Once I get the new PLL installed...we'll see what happens (or what else is not working).
I do not see any other mods to the radio (the original C179 is still installed, Clarifier & ALC circuits are factory). The radio was a good find!
