I have a 1/2 wave horizontal dipole I put up about two years ago...works great.
I'm getting ready to put up a second one in another spot to radiate North & South. This one gives me some opportunities regarding mounting points.. Crude pencil drawing below hopefully explains that.
I would like to have the feed point with balun attached to the center 20' fiberglass pole (already in place) so that the coax would go straight down the pole from the mounting point. One end of hanging cord will be attached to a tree at 20'. The other end I can easily attach to another 20' pole.
Entire dipole array will be at 20' elevation level from the ground from one end to the other. But...looking at the wire from top or bottom it will not be a straight 180*. It will have an angle in it somewhere around 150* to 160*
What problem might I expect from this.? SWR? One side of antenna more directional than the other? Anything else?
Thanks!
As it would appear from the top looking down
Thanks!
WDX-556
Thanks!
Thanks!
WDX-556
