142 information help
kopcicle
Feb 17, 2016
2,228
3,709
273
Located in Sam's #219 is the Cobra 142 GTL PhotoFact . Does anyone have a digital copy? I seem to have lost my hard copy and obliterated my digital copy. I was attempting to help Kaos and couldn't find my information.
Sad part is that I had 20+ years of modifications and notes attached to both the hard and digital copies :-( .
I have never had the 142 manual my self but did use the TRC-450 mobile radio for the alignments and the 142 schematic off cbtricks site. I believe the washington base radio has the same adjustments as the 142 radio.
never did find the sams for this radio either. hope this helps some.
Reactions: Robb
the President Washington version has the PC385 board in it also.. this is the version just before the Uniden Washington radio. I had to do some searching to find the sams on this one to verify it was the same.
look at the trc-450 service manual and see if it has the same lay out as the 142 radio. the trc-450 has a voltage chart.it is over on cbtricks.this is a mobile but will work for a base radio as far as the main board.
