15 & 17 Meters....
Quiksilver
I Support WorldwideDX.com!
Oct 23, 2006
452
97
38
65
Washington State, USA
Is, or can SSB Phone used on 15 and/or 17meters? Would like to venture off from 10&11 meter DX and try 15 & 17, and possibly 20 meters. I run an I-10K vertical, and thinking of purchasing an antenna tuner for such operation. Is this efficiently possible, or am I reaching.
Thanks for the comments!
SSB is the primary voice mode on 20, 17 and 15 meters. USB that is. On 40 meters and below LSB is the standard.
Although you'll be able to match the radio to the tuner, I doubt your antenna is going to work very well below 11 meters. A simple dipole for the lower bands would be best. If you can't install a fan diople or seperate dipole for each band then cut it for the lowest band (20m) and use a tuner for 15 and 17.
