HI,
It is normal to see a lower PEP when adding an insulator.
The only explanation I have for it, is that with the insulator, you are no longer suceptable to the "RF Feedback Ground Loop" Problem, which I believe may have been causing 'false' PEP readings (higher than Actual) due to the generated noise on the signal by the ground loop.
I had one customer that had the same issue of 'fading' output power, and After installing the Insulator he complained of the lower power reading than he was used to..I explained my theory to him and he did some on air testing and found that a regular neighbor contact of his actually reported Higher readings from the repaired radio than from before.
Your previous problem may have been a defective final or some other circuit problem that you corrected when you re-installed the replacement final.
For a little more power, try paralleling C127 with a 680pf capacitor,
or try the 'Better High power mod' without changing the 477 final.
I find this usually will compensate for any measured power loss after an insulator install.
Roger
</p>
Roger
</p>
