2510 vs Lincoln RF-Gain
Ham Radio Nerd
Apr 14, 2002
9,321
2,012
383
My 2510 has the RF-Gain pot, whereas a Lincoln has a RF-Gain button. Does anyone know where the Lincoln's RF-Gain button would be similar to on the 2510's dial? In other words, where would I dial the 2510's rf gain to achieve the same settings as the lincoln's button? Also, I have the same question about the lincoln rf-gain with it deactivated. Did that make any sense at all? <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/ohwell.gif ALT=":">
Thx,
</p>
Got my head spinnin. (not hard to do) If asking where the rf gain knob would be turned to get the same RX as when the Loc/DX switch on the Lincoln is on Loc OR Dx, I would say you would have to set them side by side with a coax switch and switch back and forth between the two radios and see what "sounds" like the same.Couldn't really rely on the meters on the two radios because they may be adjusted differently. Why would this matter? Just tune it to where you like it.<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)">
<img src=http://www.chargerscastle.com/cbclub/hook948.gif>
Hot Rod Lincoln -Dancing around the World ! ...... 948 Central Texas, - Hook948@hotmail.com</p>
Well....I have a 2510. I use the RF-Gain quite a bit depending on the conditions or the contact. Just wonderin what the difference would be on a Lincoln. Also wonderin if the RF-Power would be more useful than the RF Gain pot, all things considered.
</p>
OK, that's some good insight into the second question. How about the original question?
</p>
Can an RF gain be added to a Lincoln using the RF power control in favor of just setting the AM power inside the radio, since that's all I would need. Is this posible, or would it be too much trouble.
CDX-350
2AK3350
</p>
  • @ heartbreaker3473:
