Retevis is giving away THREE radios for their 16th Anniversary! Click Here to enter!
You can make you radio sound different by changing caps, some people will argue if its better or not. Most likely you will have to change more than just one to make a big difference. By changing the caps you can widen your frequency response on transmit and/or receive.
I dont know about C78 (have not looked at the schematic) but if it is in the audio chain it will most likely give you more high end tones by going to a smaller cap.
I have found that widening the receive does make you radio sound better (IMO) I think it makes for easier listening and a more full sounding receive.
On the transmit side, you can do a lot to open up your transmit but it depends on a lot of variables, type of radio, what caps you change, your microphone and even your voice.
If your microphone has to much low tone changing C78 might work to give you a higher tone? (I dont know if C78 is the right cap so dont quote me)
