Which coax switch? I didn't see a link or pic?
Hi everyone,
I was wondering if these coax switch boxes were a good idea? I will be using this on 11m. Will i see higher swr's?
Thanks, TB
Are you planning to switch radios or antennas and what do the three positions do?
Ok thanks alot! I want to switch 3 radios on a vert. beam antenna. And yes I know the swr meter will lie based on changes in jumpers. But i was just wondering if it would negatively effect my station in anyway. Again thanks!
I don't see how you could possible hurt the radios unless you keyed a radio that doesn't have the coax switch put in the position for that radio. Just make sure that the unused terminals are grounded when not selected and you don't have to worry about a thing. I use a setup just like you are describing to switch between a couple of 100 watt HF radios and have never experienced any problem.
This is the Diawa CS-201 switch.
It looks to me when the switch is in the center off, both terminals are grounded....
