4TH of July Stories - Everybody has some...
Robb
Honorary Member Silent Key
I Support WorldwideDX.com!
Dec 18, 2008
11,432
3,698
323
Silicon Valley CA, Storm Lake IA
One of my twin Uncles was a gunsmith. He showed me how to make firecrackers with paper tubes scavenged from wire coat hangers and pistol powder. Had a lot of fun doing that with him, as well as learning to shoot guns - I was about 11 years old. He also taught me how to do it right - so that I didn't hurt myself or others. We also made a small cannon made out of brass that used wadding - just to get a nice bang. He showed me how to make fuses, and even ordered a 25 ft roll of underwater fuse thru the mail - so that we could make our 'fun' a bit more professional looking.
The biggest charges we made were done with acetylene and oxygen from welding tanks. We would take a plastic sandwich 'baggie' and ring all of the air out of it first. We would carefully get the right mixture out of the acetylene/oxygen tanks and fill half of the baggie - and then tie a knot to close the bag up. We then set the baggie filled with the gas mixture on the pavement and then took turns flicking matches at it from six feet away until someone got lucky. It is amazing to see just a small amount of this gas explode with the same force as a cherry bomb. Much better than the first firecrackers we made.
We used to make cannons out of old drive car drive shafts, cut one end of with a torch and blow a small hole near the opposite end (that's where you put the acetylene in for the propellant )
Just shove in some wadded up cardboard for the wadding and what ever projectile of your choice ( one that would not slug the cannon) then add the gas and fire.
Did the oxy/acetylene thing with garbage bags. Saw it done with a waterbed mattress...scary site.
Some firemen a few years back did that next to the courthouse (the station was right next to it).
Got in beaucoup trouble.
At an oil reclamation plant I used to work at, used a milk carton with acetylene in it wrapped in a paper bag.
I use black powder and plastic bottles for big bangers.
We used balloons and string for a fuse.
We (I mean my brothers and I) also used to capture these large horse flies as a child in Ms., what we would do is to shove an approximately 1'' long section on a broom straw up their rear end and release them and the resulting imbalance of the broom straw would make them fly in a vertical pattern which was straight up until they would tire and then return to earth in the opposite direction which is straight down and rear end first.
Let them rest awhile and repeat.
