6 wire D-104 Silver Eagle wiring for Ranger RCI 99N4
Bombardier
Dec 19, 2021
41
11
18
60
Hello, I need the wiring from a 6-wire D-104 Silver Eagle to a 4 pin to a Ranger RCI 99N4, please any help much appreciated. THANKS in advance, have a great day. Mark
>1-Shield and Blue
>2-White
>3-Red
>4-Black
>5-N/C
>6-N/C
>Yellow-N/C
Snatched off of Copper Electronics http://www.copperelectronics.com/discus4/messages/34/95390.html?1163827513
I'm assuming your 99N4 has the Up/Down channel selector. As does both my RCI radios. You can forget that function.
I had issue with my Golden Eagle and 5 Pin Cobra 2000.
The female connector contacts didn't match up with the Cobra male pins.
>1-Shield and Blue
>2-White
>3-Red
>4-Black
>5-N/C
>6-N/C
>Yellow-N/C
Hello,thanks,so this wiring will work on a 4 pin,correct?
Unless your count is different than mine, yes and no. I presumed your Ranger was a 6 pin mic; you didn't answer the pertinent question. The 4 connection indicated above omit the Hurst speed shift lever pins 5 and 6 in favor of the Muncie positive throw.
Reactions: walterjn
Hey ,THANKS, worked great. Much appreciated, never thought no look at Copper's website, getting good reports on the microphone. Have a great Holiday Season, be safe, take care, Mark..
