Hi, I am doing a tube socket swap on a Hy-gain 644 footwarmer which is going from 8908 tubes to EL509 tubes and am a little confused on where the pins are supposed to go from the EL509 sockets, for example there are 2 G2 on the EL509 " pins 6 and 3" so do they both have to be connected or can pin 6 be left alone ? Also if you look at the circuit board for the 8908 tubes pin 6 is basically not going anywhere and is a dead circuit so is it ok to leave one of the "G3" disconnected on the EL509 then ? Thanks
