8908 to EL509 tube socket swap
Danzik
I Support WorldwideDX.com!
Oct 18, 2022
371
86
38
48
Hi, I am doing a tube socket swap on a Hy-gain 644 footwarmer which is going from 8908 tubes to EL509 tubes and am a little confused on where the pins are supposed to go from the EL509 sockets, for example there are 2 G2 on the EL509 " pins 6 and 3" so do they both have to be connected or can pin 6 be left alone ? Also if you look at the circuit board for the 8908 tubes pin 6 is basically not going anywhere and is a dead circuit so is it ok to leave one of the "G3" disconnected on the EL509 then ? Thanks Screenshot_20221206-110445_Gallery.jpgScreenshot_20221206-121030_Gallery.jpg
The tube grids that have more than one pin connected to them can be used with just one of the pins. This is why pin 6 has no connection. Pin 2 alone is sufficient to complete the circuit for G3.
The EL509 pins are fatter than the typical american-type large 9-pin tube. It's called a "magnoval" base. You can use a more-typical american-type 9-pin tube socket, but don't try to insert an american-type 9-pin tube into that socket later on. The spring contacts will have been spread out too far to make good contact with the skinnier pin used in the american-type tubes.
There were fleabay sellers who had magnoval sockets listed back in the day. Haven't looked for that item in a while. Might be harder to find these days.
Let us know how this turns out. The 8908 is bona fide unobtanium.
10-4 ! and thank you
Svetlana EL509/6KG6 High Performance Beam Power Tetrode
