8awg radio power lead
Tokin
The Man With No Shoes
Oct 31, 2019
1,701
3,079
273
59
SandBox
Went from dropping 1.6 volts to .3 volts.
The tough part was finding the right plug to modify. It has to be a 2 piece that uses screws.
I soldered the pins directly into the 8 gauge wire then filed the plug end until i could get the pins in the plug. A little shrink tube and it was done.
I never realized there was that much loss in that one cable.
(Nice looking work!)
20+ foot main power circuit in the KW.
6-AWG keeps volt drop under .5 (under 20A total draw).
POWERWERX PD-75 to distribute juice among three (3) devices. Supplied radio cord length shortened by being wrapped thru fat snap-on ferrite ahead of transceiver.
Use of this small-but-heavy buss bar 12V panel (APP-ended cords) makes swaps E-Z. (Available on the shelf at HRO).
Granted, amp & transceiver are separate. The 1.5’ lead to amp is light gauge. Bigger amps run the same way, but heavier main & final power cords and/or shorter main circuit length.
