959 frequency display
ddbddg1
Senior Member
Dec 18, 2011
114
5
sheridan wyoming
i want to change the frequency display in my dx 959 to blue.
i found some replacements on fleabay but the trouble is, i dont know what size to get.
i dont want to take it apart untill i get the parts so i cant tell the size.
has anyone done this before and know what size i need?
thanks
thanks
Unless the display is simply plug and play that's a de-soldering and soldering job you may want to think twice about. Then again maybe your the solder King..;)
Not only that, but it's a double sided board. I usually use some nice solder wick. Or if I am out of solder wick I take some shield from an old piece of coax. Another method that works pretty well is to cover the traces with a bunch of solder and then tip the board 90° allowing the hot solder to roll off the board, it takes most of the solder with it, leaves the board CLEAN and usually the part you are working with will kinda fall out. I would not use this method with delicate parts that you intend to reuse. There is also the 'Solder Sucker' method, I have never had good luck with that
im usually pretty good with a soldering iron and i have all the tools to go with it.
i been doing it for a long time...the one thing you wont find in any tool kit tho....a steady hand!
    BLACKOUT HF
    May 15, 2024 @ 14:55 UTC
