AM delay on a 1 X 455 ?
Switch Kit
Well-Known Member
Apr 6, 2005
3,627
199
63
I have a slight problem with a 1 X 455 ,the relay seems to take a slight bit longer to open up after unkeying ? I remember having a simlar problem years ago with a small Galaxy 225 amp but I can't remember what the fix was or what part it was that I needed to change ? ....any help would surely be appreciated . Thanks Switch Kit
thanks much A-Shock !! would that be the big one in front of the relay on the left hand side of the pic ? or the little one right next to the relay on the right hand side of the pic ? thanks again A-Shock. SK
Definitely the black electrolytic cap between the two relays. Don't just pull it. A 10 uF to 22 uF cap in its place will prevent "chatter" in the relays from a radio with too much modulation.
We use a 4.7 uf across the keying transistor in all the Texas Star amps that come through here. Prevents the "mysterious shorted keying transistor" syndrome when they're used with "full sandpaper" audio from non-CB type radios. Made it a mandatory preventive measure no matter what repair it was brought in to have done.
Alrighty then !! thanks alot guys !! that surely took care of the problem. Truly appreciated the help here gentleman , I hope in the future if somebody should get one of these units that this thread will help them as well . Switch Kit
