10 meter and 12 Meter...posted in 2011, so I can hope they made some improvements...
IT will need help in antenna and counterpoise.
So since I know so little about that "box" I can only hope the BNC contains a separate connector you can use to hook up coax to a more dedicated antenna - even a thown-up-into-a-tree - can help
Thank you.. yes.. was wondering if after installing a 130cm / 51" (1/8 wave) BNC connected antenna an counterpoise would improve the performance of the handheld radio. Probably I can attach a wire into the "negative" part of the BNC to act as a counterpoise and still been able to maintain the portability (keeping it as a handheld) of the whole set up. But is it worth it? That is my question... Thanks...
Sometimes, I'll just use an adapter so I can run the AH100 to an external antenna. That antenna is frequently my simple little 1/4 wave dipole: a 102" piece of 3/4" aluminum; a rail mount and a 102" stainless steel whip on top. I take it on my boat and have managed to talk to Hawaii's big island while I was anchored off an island here in the Keys running barefoot.
Speaking of adapters... years later... I wonder if anyone has seen any adapters for the TRC-207 type antennas. Those are just a threaded female end on the radio. Would love to be able to adapt that to a female BNC.
