Any thoughts on this wire antenna?
Mudduckmobile
Oct 5, 2015
643
347
S.W. Washington Coast
This is called a "Bi-square" or "Saturn" antenna. Any of you wire antenna guys know about this?
I was looking at this today....again, and I don't see nor can I fine any measurements for the gap at the top of the antenna.
And could I use a bit of 75 ohm coax as a matching stub or would it be best to just use the same wire as the antenna?
Anyone know where I can find some more reliable info on this antenna?
Thank you!
http://cb-antennas.com/wp-content/uploads/2013/12/saturn1.pdf
I don't know much about it but it looks like a fun project. You might be able to get a match with the 75 ohm coax but it would have more loss. It would be best to use balanced feed line like they recommend. I would use the same wire to build the ladder line.
I may have missed it but I didn't see any mention of a balun. I would use a 1:1 balun where the ladder line and coax meet.
The gap at the top shouldn't be too critical. It looks like it's spaced 65mm....I looked up the insulator on the website he linked and put the description into google translator.
65mm lang - 15mm breit - 8mm hoch = 65mm long - 15mm wide - 8mm high
Interesting read thanks for posting the link.
I am curious as to height AGL the dipole was modeled at?
Looking at the lobes I would think 1wl AGL,
Wonder if instead of an open end at the top, if a resistor could be placed there to have a direct feed 50 ohm match,
Might be worth playing with just to see how it does
Also reduce each side to 3/4 wl to achieve a 50 ohm impedance at the feedpoint.. Dunno what this would do for the radiation pattern though.
I have an unused pully on the tower I may play around with this one see how it does
Good look'en thank you.
Let me/us know if you do it, (3/4 wave) it would be nice not have to match it. Just plug and play. And what type of resistor would be needed if put at the top?
Man-o-Man. The W8ji link is soooooo cool, Thank you! And I meen the whole site, I am learning so much stuff here. Things I thought I knew some about, I knew nothing about, I'm really getting something from this. Thank you again.
FWIW Tom (Charles), W8JI knows his stuff. He is the amplifier designer for Ameritron BTW.
I also think he(W8JI) was asked by Heathkit to help with design of the SB-220/1 and the SB-1000 amplifiers...
Antenna and Amplifier info...I would trust Him (W8JI) and Bill Orr's info before all else!
All the Best
Gary
Indeed. You could do far worse following someone else's advice.
Reactions: Mudduckmobile
All the Best
Gary
Thank you. This is some of the best info. I have gotten on this form. A true school on antennas, and radio too.Thank you.
Do you think I can use the BuxComm 1080T2FD-1400 on 11 meters and see a swr below 1:4 as my amp does not like to high swrs+1:4) with out useing an ATU?
Once I get my ticket I can use the other bands....After my wife heals up from her operation I can test at last....this has been a bad last 2 years for her.....I kind of have become house bound caring for her.... but thats cool and not what I'm talk about....
Thanks for your time.
ON4UN has some good low band DXing books also
Bill ORR good one BJ definite read material in the shack
