Anytone 5555 identification.
Grinder74
KE8EOJ
Sep 23, 2012
215
48
38
How can I tell what version I'm looking at? One is for sale near me and owner has no clue of age/version.
Thanks,
GRINDER797
You'd have to see pictures to distinguish which model and serial number to tell of its age.
There are now 4 models of the 5555 for sale (with many clones under different aliases)
The original at-5555 with different revisions
The first version at-5555N probably some revisions
The at-5555 plus (recently released).
Soon to be released at-5555 plus/n (if that doesn't add to the confusion)
The at-5555N II (recently released)
Of the previous models you'd probably have to go by serial number to determine the age which would then help you figure out which revision it is.
Kind of a pain if it isn't in front of you.....
If it is not an N model, then you will likely need to look at the board inside to see the version number. If it is the newest “plus” model, then that one looks the same on the outside, but is completely different inside and has no adjustments inside the unit.
I believe that the versions with the new smaller, no physical adjustments inside boards have cooling vents on the covers. Problem is you would have to see the actual radio (or a photo) to tell. Many places selling these (and the new Strykers) are using old photos so buyer beware!
JD
Reactions: Eldorado828
  • @ Hambones amps:
