Anytone 6666 Pro 11 Meter Conversion
Riverman
I Support WorldwideDX.com!
Nov 12, 2013
3,081
3,468
273
Can someone clear this up for me please?
I know the original 6666 can be converted by holding the Memory and Band buttons while turning on the power. And while some say this works with the Pro version as well, I’ve heard others say it does not.
Which is it?
Thanks!
Still confused. Is moving the jumper needed for 11 Meters? Or is that just for 15 Meters?
That's all is need for full TX expansion for 10, 11, 12 and 15m.
You can set the radio for HAM bands and you only get the full 10m band while setting it up HF bands you get 24.715 Mhz to 31.105 Mhz and on 15m the range is limited to 21.000 to 21.500 Mhz and power is reduced to about 40 watts.
Do this with the radio off and hold the BAND and MEM key while powering on and use the VFO to select HAM or HF. Long press the BAND key if you want VFO display with Channels and channel bank letters or just frequency display only.
