Anytone 6666 + Signalink
MarHazK
New Member
Apr 11, 2022
2
Im just wondering which Signalink model or any audio/sound interface that compatible with Anytone AT-6666? Im planning to have one for FT8 on 10m/11m band on that radio
Since there's no data jack, you'll have to go off the mic plug. Looks like there's no RX audio on the mic plug, so you'll have to go thru the speaker jack in the back. I suppose you could test the two "NC" pins to see if there is actually RX audio on one of them. Guessing it won't be the center pin, most of the time, those are for +8-13.8 volts. Maybe Pin 4 has RX audio on it. Any interface should work, even the Easy Digi interface. I've bought a bunch from this guy to sell to our local club members as kits.
I use that same setup for JS8Call and ROS sometimes. It works well. Keep your digital mode TX around 10w, if you go too much higher you will get a hot radio and splatter. I have a fan behind it blowing on the radio when I do digital stuff.
Reactions: Pez
What is the reason for a 8 volt pin in the mic socket.
I myself found it useful for my d104 to eliminate the need for a battery.
  • @ heartbreaker3473:
