Anytone At-6666 Pro
I'm gonna hide behind a wall and throw this out there... GNF. lots of people would love to destroy GNF, and it only seems to work with very strong signals. to keep post related, does anybody have insight on the variable nrc for the q6p? i would imagine it works far better than the all or nothin nrc of the k-po dx5000
Yeah, the GNF feature was better than nothing. But the DSP noise reduction that these new radios have is like night and day. I usually run mine on level 2 and occasionally turn it off to see the difference it makes, it has spoiled me. Now it is hard, almost painful to listen to my old radios...
These new radios have spoiled me and it's hard to go back.
I made a Florida & Oklahoma contact with my Lincoln II+ today running barefoot full power and that is a noise y radio but my West Mountain Radio processor Tamed the noise and made it enjoyable. I've run my DX 2547 with that proccesor and was pleased with the results. They are pricey but worth it in my opinion for what it is worth ! LOL
On 15 meters SSB Power All Way Up 20 to 25 watts. SWR is 1.2 The antenna is a G5RV DIPOLE 80 meters to 10 meters. My meter is a Diamond sx-600. I was disappointed that this is all it would do on 15 meters but as the gentlemen had stated earlier this band was extra and not really intended to be fully operational as it is for all other bands. The other bands I have tested from 10 meters to 12 meters performs very well with the power doing as stated by the manufacture of the radio. By the way, has anyone discovered how to do the swing diode modification for this radio yet?
Reactions: FlyBoy50
If anyone is having issues with the radio showing high SWR even though your SWR is fine according to your external meter, Delboy.s web page there is a 1.02 firmware in Beta format that can be used to correct this problem. So far on the Anyone web page they haven't shown it yet.
Reactions: FlyBoy50
Someone knows a mod to unlock modulation limiter ? Wanna aprox the rms modulation with pep, so i can use less power to drive an amp
I think that radio has a hidden service menu with lots of settings, be careful if you decide to try this. You might look into the NPC mod for this radio, it should be the same for the Stryker 955. Not really sure what your trying to do there but clipping a limiter won't do anything positive for you.
Reactions: NZ8N
I saw a guy that equilibrates the RMS and PEP modulation, is useful to down the power and drive an amplifier. Cause 6666pro have much peak power. When stock, i set it to 20w rms and pep goes almost 55w. But if i set pep to 20w, i got bout 8w rms. I tryed npc mod, didnt help at all. I use it most SSB. In a video, i got some clue about a capacitor and some components added in the npc area, but i cant figure it out.
Reactions: Lawrence lin
It's all in the service menu. You can make that radio give you nearly any pep out of any RMS setting. When I first got mine to play with I set it up key 1/2 watt and swing to 6 watts to be able to drive a single pill. On SSB I had it all the way down to 4 W pep, and as high as 85 W pep when turned up. Once the complete channel expansion is done, there's never a need to open the case again. Just be careful what you change in that menu.
Reactions: NZ8N
keep trimming the mic gain back with the radio left stock? i used a mechanical meter to monitor amp current draw, and to smooth out the peaks coming from the qt80 (user) settings. had to back the mic gain down to '34" and power at "8"(not o'clock) to keep her out of overdrive on a 2x2879, mic 34 pwr level 4 for a 2x2290 box. i set the radio to pep drive the pills at their manufacturer output spec. if it swings a shade more at 13.8v @1.1swr, there's some headroom. you can do dang near anything with these radios
Just to add another data point, I received a new AT-6666Pro yesterday (via Amazon). It came with version 1.01 firmware installed.
The version 1.02 test data tool gave a "communitation error" on radio read (data cable had a CH343 chip). Installed the 1.03 version tool & it read with no trouble so I have a good backup of my original settings.
I did see the issue of disappearing M/N/O bands while testing with CPS 2.05. I.E. if you save read radio data, close the CPS program & restart it, when you read the data back, M/N/O are gone, CPS pull down list only goes through "L". If you read from the radio first, then read the saved data, M/N/O are present in the CPS pull down list.
I'm still doing familiarization/backups. I'll probably do some xmit tests into a dummy load next for baseline & to verify function.
BTW It was a " prime spring deal" from one vendor at Amazon for $254. https://www.amazon.com/dp/B0D9CVXQR3?tag=worradfor-20
You dont have to use the cps 2.05 Use the cps 2.02 and you will have all the bands for the radio. The cps 2.02 works with all the firmware.
Pxistaa , can you post the video of the npc mod for the 6666pro or let us know where to go on the web to watch it? The 6666pro is not the same board as the at-6666
