ARF 2001 microphone info wanted
TM86
Supporting Member
Jul 6, 2014
1,687
2,575
273
Payson, AZ
Going for the longshot. Looking for a schematic for the speech processor board that ARF stuffed inside the base of the D104's they modified. Even a reverse engineered and drawn on lined paper diagram would suffice.
I'm guessing that the microphones themselves have been unobtainium for at least 20 years by this point. A dead one of those would be something to work from, but they're most likely all in landfills scattered around the country by now. Any working ones should be attached to the radio they came with, so I doubt the owner would want to disassemble it just to see what's in it. I'd appreciate it, but the odds are against it.
I've checked the service manual that's available online, nothing there unless I misinterpreted it.
Like I said, longshot. But I figured if anyone had the info, it would be someone from here.
I would like to know more about the mic issue. I have 2 freinds one of them has a 2001 he says he cant use because he doesent have the special mic, the other freind has 2 2001s and he said he used a regular mic with the one that he used.
Since July I've managed to get my grubby little paws on a schematic for the custom circuit in the ARF specific D104. It's a preamp that uses a single FET and is powered from the radio at 14 volts via pin 4 of the mic connector. According to said schematic, pin 1 is audio, pin 2 is shield (ground), and pin 3 is PTT which gets connected to ground to key the radio.
For testing I'm currently using a Royce hand mic that happened to be wired correctly that I had laying around. It keys and modulates. How good it sounds I can't say, but it does work.
    63Sprint has left the room.
