Astatic 636L wired to 8 pin Yaesu?
YAESU-FT950
PIN1 MIC UP
PIN2 + 5 VOLTS
PIN3 DOWN
PIN4 FAST SCAN
PIN5 GROUND
PIN6 PTT
PIN7 SCREEN/EARTH
PIN8 MIC
Pins 6, 7 & 8 should be the pins to be concerned with on the FT-950.
I don't have info on the 636L but would assume it to be the same as D104??
David
Thanks David, I figured it out
pin 8 white
pin 7 blue/shield
pin 6 red
pin 5 black
Yellow is not used
thanks for the reply
Reactions: Dmans
