Baluns, baluns, baluns
Pman62
Nov 20, 2017
47
20
18
64
I have researching home brewed baluns and have a question that I can't seem to find an answer for. As far as 1:1 current baluns go, I have seen bifilar and trifilar wound designs. Are there advantages/disadvantages to either design?
Err.... I guess I may have had a senior moment. The trifilar wound baluns are voltage baluns, not current baluns. So, I guess I got my answer.
Reactions: 2RT307
As additional info: The voltage balun is good for a balanced load such as a dipole, whereas the current balun can be used for either balanced or unbalanced applications. A 4:1 or 6:1 current balun is best used for an Off-Center-Fed-Dipole (OCFD) antenna, depending on the antennas height. The 4:1 or 6:1 can be used on an OCFD by itself if the power level is 200 Watts or less. When going above it is suggested to add a 1:1 current balun usually built with two ferrite cores and RG-142/U or RG-303/U coax. More windings applied provide better isolation at low frequencies (i.e., 160 and 80 meters). Use a Reisert winding to provide a convenient mechanical input and output format. The Reisert winding is where the first half of the winding is brought back to the initial start point and then continued until the other half of the core is wound. This will provide an input on one side, and the output on the other side.
73,
Mike
Thanks for the info. Yeah, I've just started back in on this hobby after a long time and I realize just how much I've forgotten. Hell, it's been a good 17 years since I last switched on my o scope. I'm probably going to have to go through all my test equipment with a can of Deoxit.
