Base antenna
Jugge265
New Member
Apr 15, 2018
18
2
3
35
Putting a base station in. I have a steel pipe drove in ground. going to mount my 20 ft antenna to the pipe that is even with eve of my house. How high do I need to put the antenna above the house? Mount the antenna to top of post or mount it on down the pipe?
265, have you figured out what antenna you want to install?
Higher is always better, but try and get the bottom of the antenna a few feet above the highest point on your roof...at least 5' feet or more..
Yes it's a Shakespeare 20ft fiberglass. The top of the antenna will be around 35 to 40 ft off the ground and I live on top of hill compared to everybody around me
Mount the antenna as high as possible.
It's the height above ground at the base of the antenna that matters more.
1 wavelength of the frequency you use is best especially for ground wave. This would be 36ft at 27 MHz.
This height usually requires guy wires for support.
18ft (1/2 wavelength) at the base of the antenna will be a good compromise for local and DX since you have elevation over other local stations. DX will still be good at the elevation at your location but it won't come into play like it will on ground wave unless your antenna is right on a hill.
Would it be better if I put the metal pole to the side of the side of the chimney? Let it sit about 2ft below the top of the chimney (enough to mount the pole) the attach the antenna to the metal pole. The would out the base of the antenna about 25 to 30 feet off the ground
Higher is better for local comms, for DX it makes no difference for a vertical antenna. If there's a hill blocking line of sight between your antenna and a local station you want to talk to you're still not going to be able to talk to them no matter what you do. Being on high ground above everyone else will give you enough of an advantage that height won't matter for local contacts.
I didn't know you were still on the cb. I guess i need to put up a beam pointing east.
say when! I'll swing the house around back west.
I do live in hills and hollars I'm just on top of hill compared to the town where I live. What would be a good antenna? The one I'm putting up is a Shakespeare it was give to me a few years back but would like to upgrade
