Best antenna Cb baSe
Dragos Gheorghe
New Member
Apr 19, 2020
5
Hello dear friends , i am new in radiocomunication , my name is Dragos , i am from Romania. Now i am using a 1/2 wave antena albrecht (5,5meters) and a crt 6900n , only citizen band. I want to upgrade my antenna , what is your suggestion ? Please excuse my bad english.Thank you very much !
Welcome to the forum Dragos. Your English is fine.
What kind of 1/2 wave (model ?) are you using? Tell us something about your installation. Maybe you could send us pictures.
Reactions: Dragos Gheorghe
Dragos:
Any 5/8 wave antenna is going to have more gain, so it is always preferred over using a 1/2 wave.
If you can get the Sirio 827, then that will be just fine.
Mount the antenna 30 ft above the ground for best results. Make sure that if it should fall, that it cannot cross any mains power lines. And be sure to put a ground rod at the antenna mast base for lightning protection.
