Best base antenna for rental house
Rabbid Possum
Jul 26, 2021
163
385
Tennessee
Does anyone have any suggestions for a base antenna for a rental house? Unfortunately since I am renting and hope to buy some land and build within the next 1 to 2 years I can't do a tower. Was thinking I could use my dog kennel to mount to possibly?
Any help is greatly appreciated as I am a complete newbie to this hobby.
Thanks
A99 or other vertical on a pole or in a tree. A dipole maybe? Maybe one of those fancy PVC dipoles that you can rotate, for the lulz ya know?
Thanks for your input. I've got to get me a base up and running as for now I only have my rig in my truck and mainly only get to play on it when I am at my part time job
I don't think they're made anymore but if you can find one, the workman t-225 balcony antenna did a great job once for me. Used it for several years on and off and still have it put away as a back up. It's a boomerang type antenna. Sirio makes one like it and I even tried it but it wouldn't work for me.
Have any tall trees? Spray paint an Imax or a-99 brown/black and use rope to pull it up into a tree. If you had a pine tree you could loop a rope over a branch in the top and pull the antenna up into the tree up against the trunk, should be pretty invisible if you do it right and can be temporary if you leave the rope in place to raise/lower it. Or like others have said - put up a dipole - very low visibility.
Thanks
seeing some of the comments i just have to ask you, are there any trees on your property?
Unfortunately no trees at all
    boog351 has left the room.
