Hmmmmm. Uh, Richard the bandwidth for the HF slugs is wider as a proportion, from lowest to highest. Bandwidth issues are generally described as a proportion, rather than so many MHz, in my experience.
25 to 60 MHz is a range of 2.4-to-1. 50 to 125 mHz is 2.5, 100 to 250 MHz is 2.5, 200 to 500, and 400 to 1000 and so on as the letters go up from "A" to "E".
First experience with the Bird 43 was entirely 25 MHz and up, an FM 2-way tool, or so I thought. Had never seen one before getting hired by the local Motorola shop. Had no idea it would cover below 25 MHz until a few years later.
But 2 MHz to 30 is a fifteen-to-one bandwidth. Always figured the "H" elements were higher because it's just tougher to flatten the frequency response over a 15-to-1 band than a 2.5-to-one band.
Folks for years have asked why the built-in "relative" RF meter in ham HF transceivers and linears always has a knob to set the sensitivity. Sometimes it's on the front panel, usually on the rear. I explain that eliminating that control would cost a bundle. A 'relative' RF meter function is cheap to build into the radio. A broadbanded wattmeter is not.
And then there were the "Firebird" and "Black Cat" wattmeters. Used to get a reaction from CB operators by patching my 3-Watt 2 meter HT into a Black Cat 2000-Watt meter, on a dummy load. When they saw a reading of around 400 Watts, I'd hear things like "I gotta get me one of these". Until I explained that it really was only three Watts. On the Bird, with the "C" slug.
Got a real appreciation for the engineering inside those "slugs" first time I tried to build a RF wattmeter from scratch, and level the frequency response. Not as easy as it sounds.
