A Winner has been selected for the 2025 Radioddity Cyber Monday giveaway! Click Here to see who won!
Why not assemble the antenna and then simply run wire from point A to point B as it calls for in the instructions? No measurements necessary. It shows the attachment points.
Well if the rest of the antenna is built according to the manual that pretty much leaves the lengths of the wires a given. Common sense says that you would not want to have them really loose and sagging nor guitar string tight.
